S Space Signal Well-Known SatelliteGuys Member Original poster Mar 8, 2006 34 0 Aug 3, 2007 #1 Would Skype work to dial out to avoid phone fee?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,731 29,519 Newington, CT Aug 3, 2007 #2 Nope. I tried doing it.
digiblur SatelliteGuys Master Jun 8, 2005 14,190 4 Louisiana Aug 3, 2007 #3 Space Signal said: Would Skype work to dial out to avoid phone fee? Click to expand... FWD and Gizmo/SIPPhone work.
bacchus101 SatelliteGuys Pro Aug 10, 2006 500 20 . Aug 3, 2007 #4 Asterisk works and you can push the CLID of your choice.
pabeader SatelliteGuys Pro Jul 18, 2004 1,709 0 OTP Georgia Aug 3, 2007 #5 neighbor uses skype. he siad he had to tweak the setup to get max quality. switched dish receiver to rotary. i use vonage. added *99 to call out and left it as tone dial. your milage may vary.
D dvbfan Well-Known SatelliteGuys Member Sep 1, 2006 31 0 Aug 4, 2007 #6 How do you make PC Skype to work? Doesn't Skype requires you to have a PC on all the time? Is there a phone adapter only for Skype that connects straight to router/hub without PC being on?
