Live Earth | Page 2 | SatelliteGuys.US
Live Earth
Ok here is the info I got...
Someone decode please. :)
World Feed Path
HD Parameters SD Parameters
Symbol Rate: 28.0 Symbol Rate: 6.9
Data Rate: 38.7059 Data Rate: 9.5382
FEC: 3/4 FEC: 3/4
SD (4x3 format) >> >> Napa >> IS-8/12C ch. 16 >> POR
(fiber from FUS) >>
IS-9/12C-B >> S.America (PAL)
FUS
SD (from IS-12/1K) >> >> Atlanta >>
IS-3/5C-E >> S. America (NTSC)
(fiber from FUS) >>
G25/5C D4 >> N. America
HD BBC >> IS-3/16K >> Atlanta >> G25/1C >> N.America
London
I have been looking for an HD feed but I could not find one.
The above SD feed (Galaxy 25 3806 V 6900) is quite strong here in Los Angeles and I can pick it up on a 1.2 Meter dish with my Pansat 3500 at around 30% quality.
From Ricks Satellite Wildfeeds and Backhaul Forum:
Japan HD
Galaxy 23
3920 H 28000
Australia HD
Galaxy 27
4120 H 28000
CHANNEL
Name: "LEJAPAN 1" Provider: "DTAGS"
TRANSPONDER
3919, H, 28000 QPSK
121.0°W (2390 - Echostar 9)
Signal: 74% Quality: 34%
VIDEO
4:2:0 1920x1080 25fps 164kbps 16:9
IDs
NetwordID: 65535 TransponderID: 1 ServiceID: 1
PIDs
Video: 308 Audio: 256 - eng (ISO13818)
PCR: 8190 PMT: 32 Teletext: 0
DATE/TIME
7/7/2007 1:11:55 AM (GMT -5)
No breakups :)
I can pickup the Japan HD Galaxy 23 3920 H 28000 at 30% on my 1.2 Meter dish.
I can not pick up the Australian HD, it is around 10%.
The Australian HD feed comes in fine on a 7 1/2 foot dish. It's a rare Cband feed on Galaxy 27, since it was resurrected after it went spinning out of control a few years ago.
Is 30% watchable for you? If so, what receiver are you using? It seems that if I can't get 40+ on the fortec, the twinhan will not tune it.
So far i can't lock Austraila.
My signal of 30% quality is from my Pansat 3500 quality level.
I am watching the Japan feed on my Twinhan without any problems.
From your earlier post Scottc98 , you said the Japan feed is at Signal: 74% Quality: 34%, does that mean you can not watch it?
Nah....it comes in fine :)
For some reason, my twinhan signal reading are off. May be the BDA drivers. I basically go off the fortec readings to see if I can tune. The fortec was showing 46-53 on japan.
Gave up on the aussies....back to japan.
Be nice to see the G25 feed come back up.
BTW....nothing still on IS9 from the test feeds I saw earlier
The sd feed on galaxy 25 looks almost as good as the Hd feed on Galaxy 27 on 129
SD Feed
Galaxy 25
3805 V 6900
Vpid 308 Apid 256 PCR 308
This is really nice.The world feeds starts at 9.00 GMT on galaxy 25.You can watch it in HD if desired.
Also if you do not have access to C-Band or FTA you can watch the streaming video from all the concert locations at
Note the site works better with Internet Explorer, and it will tell you that. :(
Live Earth on MSN: The Concerts For A Climate In Crisis
Click on the "Watch The Show" link and then select which location you want to watch,
Also a nice feature under each location is it says who is currently playing and who is up next at the location.
CHANNEL
TRANSPONDER
3919, H, 28000 QPSK
VIDEO
IDs
PIDs
DATE/TIME
No breakups :)
3919 on EchoStar9? I think you meant Galaxy 23.
Old Discarded Reflectors & BUD's
Help Identifying Dish
