ABC NewsNow Stutter effect | SatelliteGuys.US
I watched it a good portion of the day on the Saturday and Sunday and noticed no stutter effect. Are you sure you've got your dish tweaked and aren't loosing signal?
Yes my dish is tweaked.... my signal strength is 77-78 on the Traxis 3500. About every 5 seconds I get the stutter effect. No other channel has that problem. It is not the tiling effect you get with low signal strength. Also the audio is not effected only the video.
I have the same problem on ABC News Now with my Traxis 3500.
Works fine on my Twinhan PCI card.
I have only seen this problem with the Traxis 3500 as well.
DTV elliptical dish-multiple feeds
Slaving Receivers
