Dish alignment or other problem? | SatelliteGuys.US
BigL
4
AU9 Slimline
H20-100
Dallas/Ft. Worth area (75454)
I have lost all Local HD channels, after a heavy rainstorm. They do show in the guide, but I get the searching for signal error. All other channels are working fine. After running setup and restarting the reciever 100 times, and calling custom service, I can only assume there is a problem at the dish.
The DFW HD Locals are on 103, if I am not mistaken. I am getting no signal from 103. Do I need to fine tune the dish allignment or should I check something else first.
Signal Strength:
101 Odds (75 - 84)
Evens (0-100)
110 3 Trans (All 3 Mid 70's)
119 11 Trans (80-100)
99(Net10) 0 Trans (All N/A)
99(Net11) 32 Trans (All 0's)
103(Net 14) 32 Trans (All 0's)
103(Net 15) 0 Trans (All N/A)
AU9 Slimline
H20-100
Signal Strength:
101 Odds (75 - 84)
Evens (0-100)
It does sound like an alignment problem, although you MAY have water in a connection somewhere.
Try a set of rabbit ears on the back of your H20, 75454 will probably surprise you. You will have to go into the setup menu for TV antenna.
I noticed you are in Celina. Do you use an OTA antenna? That was the first thing I thought of, but was unsure if I would be able to receive any locals, being this far north. Any tips on antenna size, location (in or out), etc, would be appreciated.
I have a customer in the Westgrove area I think that is the same zip code as you gets excellent reception on an OTA antenna. I have a set of rabbit ears in a South facing window and all except CH8 come in reliably. A small antenna pointed at Cedar Hill should work well for you. A Winegard Sensar II unamplified (GS1100) should work in most attics.:)
Thanks...... I am in Melissa, so I will give that a shot. It will be more than a week before someone can come to repoint the dish.
phone lines
