Where to buy new original 508 remote? | SatelliteGuys.US
Racer47
37
I am not having any luck finding a replacement remote for my parents 508. I'd like to get a new one just like the original. Anyone know where I could find one?
There are plenty of used ones on ebay. I bought one. It never really worked well. I know a newer model remote will work but it would be easier on them if the new remote was exactly the same as their current one.
Thanks in advance for any info. I've been around here a long time just never had any reason to post.
I think all the buttons on the remote that dish will send you are in the same place as the original 508 remote, its a little larger and easier to hold in your hand and much better in my opinion. Give them a call, it might be free.
Wrong Satellite
Signal Meter Changes Coming
