HR20-700 CE Software Release CE0716 Coming | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,759
29,601
Newington, CT
From Earl at DBSTalk it looks like there could be a CE rollout for the HR20-700 Tommorow and Saturday Night.
http://www.dbstalk.com/showthread.php?t=85640
NOTE: This is for the HR20-700 Only;
The HR20-100 is not part of this CE
Window of opportunity to download:
Friday; May 25, 2007 11PM - 2:30AM ET
Saturday; May 26, 2007 11PM - 2:30AM ET
Time and availability subject to change
Please monitor the threads, 40% chance the CE will happen... but until it does... anything can change.
Remember only grab CE's if you dont mind some bugs, as this is not fully tested software.
This update 0x16? will introduce the new GUI new look (white). It is MOST important that DBSTalk get's feedback on it. These Beta releases are not
supported by D*, so you should join Earl's CE forum for any help if it should
"brick" your box. CSR's will NOT be able to help you. FWIW...
okay, guys, this is already been in beta as was discussed during the first quarter webcast. chase carey said the launch date is sometime this summer. yes, i know the press release said july. but that info was released, like 2 months ago or so!
You're assuming VOD will launch on time. ;)
Also assuming they will roll VOD to the CE community. I would assume they will but you never know.
Hints have been out there that VOD has been in internal beta test for a while so we may see it soon.
Some things to keep in mind
What you need to know about the CE testing (from DBSTalk):
These versions that will be "exposed", have only gone through "moderate" testing. Not the entire cycle. There is an INCREASED chance that a major bug may exist in the version... There is a chance of DECREASED performance. There is a chance that the entire unit may just stop working...
While that is not the goal of any version "offered", as any of you software developers know.. .that is why you test, even for the tinest of changes... you still have to test it.
SO, I WANT TO MAKE IT CRYSTAL CLEAR about what it means to "download" a cutting edge version...
If you download it... there are no guarantees of anything.
You should NOT download a CE version, just to "try it out"
You should NOT download a CE version, just because it has a "feature"
You should NOT download a CE version, just to "see" it
You shoud ONLY download a CE version, if you know what you are doing and are 100% willing to take the risk. Risk = Reward.
If you have ZERO desire to deal with the RISK involved. DO NOT force the download.
In other words, download it only if you want to test and don't mind having new bugs or possible missing recordings and such. :)
actually, i'm not assuming vod will launch on time. carey said in the first quarter website that it would be sometime this summer. he also said it was currently being beta tested.
i mentioned the press release from a few months ago because i recall it said a july launch. however, the company ceo said three weeks ago....sometime this summer!
There was a fairly stong 'hint' that it was in beta testing when someone posted screen shots on another site from their own unit showing some of the VOD screens. I've seen July and summer mentioned as dates for availability. Well July isn't here yet and summer goes until late September so they're not late yet;)
I have seen the VOD, it knocks the socks off what Dish has planned. Too bad when I saw it I didn't have a camera.
It is an exciting time. :)
HR20 Changes
http://www.dbstalk.com/showthread.php?t=88304
Improved
SWM channel tuning reliability
My Playlist -> Category Sort/Search
Stability
Caller ID and "Unkown/Unkown" Popup
Recorded program playback is not interrupted when a scheduled recording starts
"Pinky" has been... removed
Acquiring Guide Data OSD (On Screen Display), surpressed during recorded playback
Improved Trickplay
Improved single tuner operation
Network Setup - "Connect Now" will not set Static IP if IP address did not change
Updated
The entire GUI, to the New "White" GUI
Pressing EXIT on an iTV app while in recorded playback stops only the iTV app
Scrolling option in setup
One button guide in setup
"Static" is displayed next to IP address in system info when static IP is in use (using static IP is not recommended)
More on screen remote control codes, for remote setup screen
Removed display of yellow icon in the channel banner, if only one audio track is available
Progress bar will update when a stop time extension is added to the currently-recording program
New feature(s)
Added group-play in the Playlist that plays all programs within a group one after the other
Added display of conflicting programs in the To Do List
Notes
Caller ID is not 100%
Picture may freeze (still frame) when doing 6s jump back
Feedback... Feedback... Feedback... If there was ever a CE todate where feedback was most critical... this is the one.
I feel like a real ass right now, I just spent 20 minutes trying to download it before realizing it is tommorrow night. :(
Brewer - very disappointed in your avatar change :)
VERY excited for this CE - lots of testing...
yes hd on directv
Moving and "moving" at the same time
