Just got a new HR20-100 | Page 2 | SatelliteGuys.US
Im not an ex customer, im a customer turned inactive account by audit peons after i passed every audit(7-10 total 4-5 in prior 2 month period search my audit team threads for more details)
there reason for turning my account inactive was moving, ill continue to bitch till cows come home and someday soon i will be a active *ish customer
never had the hd package on 622 and always got nickel and dimed with fees
had hd pack on 942 right before 622 came out
for me even with the no cid prob on my hr20-100 its far better than any *ish product
the hr20-100 looks visually stunning to me at least
under the hood i prefer the hr20-700 as ive never had any problem with the hr20-700's
Dtv is joy *ish is ish imho
hope this helps ya:)
It does, thanks.
I believe I will try out Directv and the HR-20. The 622 is manufactured as cheaply as possible and it shows.
Dish CSR's are worthless, Tech support is 50-50 and the local installers just don't care!!!
yes cid caller id
every cid capable box in my house plugged is in they all function except hr20-100 in fact when i plug just phoneline into hr20-100 it kills my main phoneline no dialtone nothing
if i unplug phoneline or use dsl filter my main phoneline works
i have cable internet and not dsl so i should need the filter
my phone is comcast digital phone not voip
as i said every other cid capable ird i have functions fine with no filters
when filter on hr20-100 call comes through with absoulutely no cid display from hr20-100
i have 2 other hr20-700 np cid works great no filters
hr20-100 was installed 2-3 days ago and actually tried 2 hr20-100 units while installing and both untis had same cid problems as described above
hopefully this is just a software issue
Like I said, my HR20-100 is working great with caller ID. I belive I read on another forum somewhere that one of the possible causes for caller id problems could be not having proper grounding, you want to check into it.
my dish is grounded to code as all my dishes are, thanks for the suggestion i read that as well
All Hr20-100's got a new software update (146) on Saturday morning.
This version basically is the same one the the 700's now have (145)
Version 146 fixes many problems, including some caller ID issues.
Help please. Multiswitch & DVR install
need 5 LNB coords...why don't they post these?
