Suppose I have a spare 18" or 20" dish lying around...is it at all possible to point that and pick up Hispasat? If not, what's the minimum size dish I would need, being located in New England?
yesAre all the signals on Hispasat linear polarities?
yepU getting it Iceberg?
Starchoice 37x27 dish with factory SC quad LNB. Using sat B (the one with the 22k built in)..Minneapolis MN (9 degree elevation)What's your dish and lnb if you are?
my thread on itSteady solid signal?
noDoes Hispasat require a Universal LNB?
I dont think so but not 100% sure.What about Intelsat 3R?
Well, I'm going to try it with a 33" dish and an xtreme II 0.3 lnb. Worst case scenario, I end up with another dish on the roof that I can aim at G10R or AMC6. There's always something I wouldn't mind not having to motor over to.
Let us know how you make out. My girlfriend would love it if I can get it. What region are you in?
Yes you can get it on an 18 inch. Most channels anyway.
I get about 45% quality on 11885 V.
The hardest part was mounting the LNB in just the right spot. I would like to make a better bracket, but haven't got to it yet.
I had actually had a 76cm aimed at it before to scan in the channels, then hooked up the 18inch to try. So I had a known good signal to look for.
Been using the 18 all winter, works "most" of the time.
Unless it rains hard![]()
Limited time offer
