Tips for a 5LNB install. | Page 4 | SatelliteGuys.US
Hmm a friend of mine thinks there is some type of adapter available? Maybe this is something that was home made but not sure. I have get more details.
Hey T,
Yous don need no freakin mutiswitch. They putone in da arm fer yous!
Jes like it! (no additional components required) Ground it or else!
Joe
Just finished ordering my Direct system and wanted to know how many cables come off of the 5LNB dish? MY Dish system has two cables and wasn't sure about Directs. I am going to run the cable underground from where my Dish is setup ahead of the schedule time to install so all the tech needs to do is put the dish on the post, connect there and in the house. Thanks
The built in multiswitch has four outputs. If you need more, then you need the Zinwell 6x8 or 6x16 multiswitch.
Max number of receivers on a single dish
Returning Customer Deals
