KU question | SatelliteGuys.US
KU question
rcthkd
4
Hello,
Hope this is in the correct area.
I started to have problems picking up channel X4 604 about 1 month ago, It was coming in fine until then. Now it comes and goes, when it does come in the signal is strong 85-95, when not comming in it is at 1, other channles don't seem to be affected,that I know of, I've checked 600 & 603 those 2 come in good. The KU components are about 1 year old.
Any ideas, need more info
Let me know
thanks
Rick
Hello,
Let me know
thanks
Rick
X4 604 is on a different transponder than X4 600 and 603. This may have something to do with it. I would check my dish alignment and coax connections first and see if that solves it. If not there may be something interfering with that transponder or something going bad in the LNB or 4DTV receiver.
Is thier other stations on that same transponder that I check to see if they are coming in?
The dish is pretty much in the open so trees should not be a problem
Rick
Rick
I think 580, 621, 720 are on the same transponder, are other V's coming in? could be the skewis off or servo went bad.
I will check those channels when the tv frees up, I do have a lnb that I am going to try to see if that cures the problem after it stops raining that is. Other channels seem to come in fine.
Rick
Yes Network / yankees
Actuator wiring question
