switches | SatelliteGuys.US
switches
hines72
4
i have 3 positions running to 1 tuner. the lnb' s are legacy. a single for 61.5 and a twin (only single outputs) for 119/110. the switches are legay (sw21). currently i have 119 and 110 combined. then that output and 61.5 are combined in the other switch. is there a separator or something i can use to split this setup to 2 tuners?
nope
you would need to duplicate that setup if you kept legacy
Then only way to use the separator is to switch to DishProPlus
You need to replace the 61.5 single with a dual and add a second SW-21 switch.
What receivers do you have if they aren't Legacy it may be better for future upgrades to upgrade now to Dish Pro electronics.
522 wierd guide on medium
Crime & Investigation Network
