Purchasing Starchoice lnbf in U.S.A.? | SatelliteGuys.US
yeas but check out all prices-- I believe kusat has the best price on 75
even with the shipping
Is there a source in the U.S. to buy the starchoice 75e quad lnbf?
do you want HD or French programming?
If not, just get a 30" dish and KU Band LNB. Almost all the English stuff is on AnikF1 so you wouldnt need an eliptical dish unless you want HD or French
I would like to have a fixed dish that will hit both satellites, as I have the HD receiver...I have a Primestar dish that is nearly the same size as the Star Choice 75e. But I need the dual lnbf, or a way to space two lnbfs at about 4 degrees apart.
A Primestar dish should work. You just need 2 KU Band LNB's that are standard (not Universal) and a 22k switch to put the signals together for each satellite
Has anyone tried.....
Missing Part of SC Channels
