Sure it will and it looks great even with a EDTV Set !!Will HD work on an edtv? I have a 42" LG plasma and having HD hooked up
Check the following thread,and special attention to the last post!
http://www.avsforum.com/avs-vb/showthread.php?t=760621
Until recently most plasmas were EDTV. Feeding an HD signal to such a set will yield a much better picture than feeding a SD signal would yield.
Yep, IMHO, you should stick with HD rather than going back to SD.
Don't hesitate to subscribe to HD. Voom and local channels look wonderful on my 18 month old Panasonic TH-37PD25 . Don't let the techno-snobs fool you. From eight feet away the difference between HDTV and EDTV is negligible. Besides, in two years new technology will render even the most expensive 1080p plasma tv obsolete. Keep your set for the time being, and start enjoying HD now. Life is short!![]()
Dude, you need your eyes checked then. EDTV is the same vertical resolution as SD but just wide and progressive scan (480p). HDTV has either 720p, 1080i or 1080p vertical resolution. The horizontal resolutions invite the HD-Lite debate so I'll not go into that here. I see a huge difference between watching a DVD in 480p vs watching something in HD.
Limited time offer
