Do I need a different dish for a 411/211 vs. and 811? | SatelliteGuys.US
purple1184
16
I want to swap out an 811 for a 211 or 411.
I have a SW21 3-Sat setup right now getting 119, 110 and 61.5 will this need to change.
no
I assume you have a Dish 500 for 110/119 and a Dish300 for 61.5 connected with a SW21.
If you need 2 recevers, just get another SW21 and repeat what you have now
For 3 receivers, I would go DishPro..much easier.
You would swap the LNB's to DishPro and get a DP34 switch. Then you can hook 4 recievers on it
no
Thanks for the reply.
I just got off the phone with a guy from the dish depot and he said that I should get a Dish Pro Twin LNB , a Dish Pro Dual LNB and a Dish Pro 34 switch.
622 Hard Drive Upgrade
