cool, can i display that in my "multimedia" link and use it that way?
what about the other patterns?
I forgot to mention you can also purchase a calibration disc calle avia Digital Video Essentials. It costs ~$16 from amazon, and I believe it even comes with a blue filter.
The link Tom posted only contains the third HD Net Test pattern.
I have attached all three HDNet test patterns as well as the INHD Test patterns.
You could burn them to a CD if your DVD player accepts CD's of JPEGs, or you could put them on a USB device and use the 622s Media Link capabilites.
Because these are JPGs I doubt it will be a very good tool to test resolution and clipping. But it should work to help adjust brightness, contrast, sharpness, convergence, and color balance.
Another option is http://www.w6rz.net/ this site contains a lot of test patterns. If you have an HDDVD player he has included an image that you can burn to an hddvd. If not you can use the .ts files to create a regular dvd with the test patterns. Using these test patterns is a little more complex, and will either require prior knowledge or some research on teh intereweb.
Take the time to get the most out of your HDTV
HD Rules!!
Just a HEADS UP
The Test pattern is in the guide for Sunday Morning at 5:50 Central Time
I'm Recording it on my 942 maybe I'll get a 622 some day![]()
Limited time offer
