CW Affiliation changes in Norfolk and other cities | Page 4 | SatelliteGuys.US
I know nothing probably changed but any rumors of them adding CW in the affected markets?
This is probably a WAVY /WVBT issue but I noticed for 43-2 my guide says "regular schedule " no actual data.
I checked fios app and they have info loaded
WVBTDT2 isn't in the OTA database, it's a victim of the having a real TMS/Gracenote stationId below 65535 (0xffff) issue. Those are stuck in their 2009 states, including entries that were inactive at the time they hit the limit.
Long story short, during the pre-transition days WVBT had a local weather channel on 43.2, but dropped it in 2007 because LIN was too lazy/cheap to comply with the E/I and EAS requirements for subchannels. So when that 65535 cutoff hit in 2009, the entry for WVBTDT2 (49031) was inactive.
this one has an antenna which i think you mentioned on AVS to get WVEC-13 sub channels
walmart-
GE Crystal Amplified HDTV Antenna, 50-mile Range, VHF UHF 1080P 4K, Black, 48732
WVEC plans to leave VHF 11 for UHF 35 by the end of the year. Unless there's something you really want to watch on True Crime Network, Outlaw, The365 or Quest, you might be better off waiting a few months.
Reactions: lordodogg
I reset the genie 2 yesterday morning now same issues.
43-2 is black screen no picture.
43-1 works
43-3 works
43-4 works
Also can't see signal strengths
Well tried switching to the flat one (bb link) and even tho it said 80 mile range was worse and didn't get any signal...
Any indoor antenna claiming an 80+ mile range is BS. Anything more than 40 usually requires an attic or outdoor antenna, and line of sight reception tends to drop off at around 70 miles. Many of them use diameters instead of the radius, so in reality the distance is half of what they list. Them not listing the actual dB gain and frequency range in the specs is a red flag too.
That GE antenna might be better as it has actual VHF dipoles you can extend and rotate it to face the tower.
Positioning/location is also everything when it comes to VHF reception, putting it near other electronics or electric outlets likely creates noise interference.
Reactions: dtv757
It probably won't be coming until the next Nexstar renewal. If future CW subchannel affiliates like your's were part of the 2023 renewal, it and the others that joined the network this past fall would have been added by now.
  • Sad
Reactions: dtv757
Some more changes coming this September
Cleveland -> CW leaving Gray's WUAB/43 for Nexstar's WBNX/55, WUAB will become a mix of MyNetworkTV and local sports
Elmira -> CW leaving Lilly's WENY-D3/38 for Nexstar's WETM-D2, Lilly hasn't yet announced what they will do with WENY's 36.3 subchannel which has the valuable channel 2 position on the local Spectrum systems.
They haven't confirmed it yet, but if Elmira's Lilly station is losing CW to a Nexstar subchannel, the same thing is probably going to happen with their Erie sister station WSEE-D2 where Nexstar owns WJET
Erie's WSEE-D2 is switching to Erie News Now on 9/1. They haven't yet confirmed which Nexstar subchannel CW will be moving to. EDIT: It will be moving to WJET-D2
Elmira's WENY-D3 is switching to their NY Local news loop.
Also, in Charlotte CW is moving to Nexstar's WMYT/55 on 9/1
WCCB/18 is going independent with a mix of SVU reruns at 8pm, an additional primetime newscast at 9pm, and local sports including the MiLB's Charlotte Knights, the USL's Charlotte Independence and High School Football on Friday nights.
Reactions: Mr Tony
DIRECTV stream
Applause for the Cause on channel 101
