Comments from a newbie to FTA | Page 9 | SatelliteGuys.US
PS- now that so many of us from this forum live in the ABQ area, I've been talking to my friend in Rio Rancho about a potential meet-n-greet for Satelliteguys members here. Maybe we could all get together at the Owl Cafe on Eubank sometime? Of course, anybody else in the region is welcome to join! Colorado, Arizona, SoCal.
TRG what say you?! dishdude dfergie
Sounds good but you'll have to catch me when Im in town. Im currently in Arizona where the temperature peaked at 115 degrees yesterday.:flame
Forget LegitFTA for now, i get all sorts of errors there when i try to add an attachment. I started a new thread here with the firmware, maybe it will get seen by more folks. Forgive me k4otl if i hijacked your thread a little bit. Back to you friend.
Code:
https://www.satelliteguys.us/xen/threads/amiko-mini-4k-uhd-s2x-v1-0-69-firmware.416520/
No problem! It's not like I "own" it anyway!
I may try out that new firmware... dumb question: If I upgrade the firmware, can I then re-upload my user database so I don't have to set up all the channels again?
Also, my V9 (or something?) has been acting up with my C band, when I first tune to 101W C band, it won't show signal, then I tune to 105W C band and back to 101W and the muxes come in fine. Any ideas? Diseqc switch?
I use a 4 port Diseqc 1.0 switch and then use a 22k switch on the output of one port to split between C band and a Standard Ku band FYI.
WPR has generally behaved for me with the Maverick PLL LNB, I honestly haven't been on Ku too much since I got C band :cool:
My family kinda (more than kinda) thinks I'm nuts for having a C band dish, or as many TV antennas and the couple of Ku dishes I have, and many hams out there are surprised that C band (or FTA) is still a thing haha.
Reactions: comfortably_numb
it's dry heat with hardly any humidity only 5 % now that's low humidity!!
Correct, it's still hot like a blast furnace, but you don't get drenched with sweat after being outside for 10 minutes. Since I moved here I learned that it's important to stay hydrated and make sure you always take a cold water bottle with you when you get in the car.
I'm adjusting...
Reactions: N5XZS
I'm adjusting...
Altitude has a lot to do with hydration as well. Denver gets the name, "Mile High City" because it's 5,280 feet above sea level. Albuquerque is actually a bit higher at 5,312 feet above sea level. So yes, it's wise to drink lots of water. Especially if you are active. My rule of thumb in the high desert is 2 liters per person, per day, minimum.
Hydration 101 | How Altitude Affects Hydration
Cn,
Since you are now living in Albuquerque, try tuning in the Mexican birds 117 W* "low and mid Ku", 78 W* 77 W* " Upper Ku" and 58 W*.
67 W* Miami and Caribbean services 4 FTE stations can be found
I noted my new V9 does a better job than Edison on 78 W* bird got about 375 stations most are scrambled and few FTA, FTE stations this bird is for HD while 58 W* is for SD.
You might get 4 FTE El Salvador Stations on 77 W* and 58 W*.
Have fun tuning in!!🙂👍 :hungry2
This is WAY off topic, but since we have so many ABQ-area folks here, is there ANY restaurant in town (or in Santa Fe) that serves Tex-Mex? You know, a place where you get a big bowl of chips, salsa, white queso, and they serve stuff like enchiladas covered in cream cheese, nachos with shredded chicken or ground beef, lots of cheese, and sour cream. Deep fried tacos, taquitos, flautas, etc. I know, I know, this is probably considered illegal in New Mexico.. This was my favorite chain back home: https://elpotrokc.com/lawrence-el-po...ence-food-menu
Blasphemy!!! New Mexican food blows away Tex Mex any day. I've never heard of cream cheese on enchiladas. All the rest of the items are available. Are you hooked on green chile yet?
You might have to go to El Paso to get tex mex, the flautas can be had at a Mexican-Mexican restaurant, I don't know about the deep fried tacos. The Whole Enchilada on the west side does Swiss cheese, tomatillo, and chicken Enchiladas that are great, their owner is from Michaocan.
172E Eutelsat 172B Ku in NA?
Is LegitFTA Down?
