CBS local station audio drops issue. Is it me? | SatelliteGuys.US
marklyn
99
97
Austin, Tx
I've noticed for months now, maybe longer, that my OTA CBS channel occasionally lose sound for a few seconds (3-5) and does a very quick video freeze, usually lasting a second or two. My antenna is on top of my house and there is no obvious obstruction in the direction of the TV towers. The NBC and ABC towers are basically next to the CBS transmitting tower and I never have had any sound losses or freeze ups on those channels. Furthermore other local non-descript channels don't do it either.
I've noticed this issue live and on recorded CBS programs.
I have a Hopper 3 with 3 Joeys.
Any thoughts or suggestions?
Have you contacted the channel about your problem?
What is your OTA signal strength on the offending channel?
Does it fluctuate?
What RF channel?
Does it occur when the antenna is connected directly to your TV?
Any large structures to either side of the signal pathway that might cause multi-path?
Reactions: charlesrshell
I have exactly the same issue at my house. It also includes the Fox station which is housed in the same building and run by the same folks as the CBS station. It happens on multiple TV's, different antennas, live or recorded on either my Tivo or my Wally. I've tried talking with the station engineer about it, he says it must be my equipment. I have very strong signals on both channels.
I've just learned to live with it and choose other hills to die on.
I'm getting the Beaumont stations.
Does it fluctuate?
What RF channel?
No I have not contacted the channel. I assume that would be a futile attempt ending with them blaming my equipment.
My OTA signal strength for this channel (042-1) stays pegged at 100% (so does the other locals, ABC, NBC, CW)
RF channel?
No large structures on either side.
I haven't connected the antenna to my TV because it is unpredictable as to when and how often it occurs and would require me sitting for long periods of time in front of the TV. It's annoying but not sure yet if I want to commit to doing that step at this time (maybe later).
Interesting. Where are you located in Texas?
It is the local station. I think it is the encoder they are using since it effects both CBS and Fox on the same broadcasting tower. I live in Nederland 10 miles from Beaumont and my ota signal is experiencing the same thing you are describing. Call channel 6 KFDM/CBS and report it to the engineer/manager. I have seen it on my Tablo as well as my ota antenna hooked to my TV too.
Business hours
8:00am - 5:00pm
Main number
(409) 892 - 6622
General Manager
(409) 895 - 4619
WAAAY back when I was using a Toshiba HDTV tuner that would receive all of my local stations easily but the ABC channel, nothing, nada, zip.
This was just about the time frame where local stations were converting their live news and other locally produced programming to HD.
I called the station and talked to the engineer and a couple of days later, VIOLA, I've got ABC in HD.
I have some trouble with a class c station here that has numerous audio and video break ups, but it is their internet connection to the main station in Midland. I just text the tech when it's acting up and he tweaks the disgronificator and gets it straightened out, so maybe not all is lost.
Also worth pointing out too much signal can cause reception issues with digital. A 100% signal strength may be over driving the receiver/decoder. A simple way to cut the signal is to put an rf splitter between the antenna and receiver.
my thoughts exactly... Ideally the signal should be around 0 dBmV by the time it hits the OTA tuner's coax input... Looks like the OTA tuner on my hopper 2 starts acting up when the signal consistently exceeds +23 dBmV, which is a helluva lot of signal... The lowest signal I reliably pull in on mine is around -11.3; it will scan ones which are much weaker, but I just don't bother with those stations.
Another option for folks using a directional antenna is to simply aim it offset from whichever is the strongest OTA signal which they intend to use; which is what I do for WITN in my area.
Channel 6 has a long history of running things on the cheap. Back in 2022, I spent about a month with Tyler the Antenna guy, helping me to write a letter of complaint to the FCC about their failing signal. Tyler helped me aim my antenna and I sent pictures of the open sky and which direction I was aiming at and I used the digital pointing app for my ota stations and I got 100% on all of the locals. But still problems with the signal dropping out on any channel 6 channel or sub channels.
Finally I contacted the channel 6 engineer himself with my complaint and he admitted they were waiting on a new encoder to be sent to them and when it was coming. Supposedly supply chain issues was causing the delay. He even emailed me the day it was up and running and I had no more problems with any of the CBS and sub channels again for like a couple of years. Now we are having the same issues again with picture freezing up like during the evening news last night and the picture was locked like that for 15 minutes. So obviously there is something wrong again with their encoder. It will take complaining to them to get them to look at it.
Time to Lock In the Savings! Well...
H392 MLB extra innings DVR playback issue
