GEOSATpro - microHD: No LNB Voltage Output | SatelliteGuys.US
GEOSATpro microHD: No LNB Voltage Output
cyberham
6,082
5,115
British Columbia
My problem symptom is simple. I have no LNB output voltage from this microHD. I have proved the receiver works fine if voltage is available to supply to the LNB. To do this test, I connected my Openbox S9 and used its loop through connector to connect the microHD. The microHD then works fine on the polarity selected by the S9.
My question: Does anybody know if there is an obvious voltage regulator chip in the microHD that could be changed to maybe fix this? There are no visually damaged components inside that are obvious such as blown electrolytic capacitors. But if I only needed to change something like a chip to fix then I would try. Even with surface mount chips which I wouldn't normally touch, I have nothing to lose as the receiver won't work as is. And, for nostalgia since it was my first good receiver, I'd like to get it working.
Does anybody have a schematic for this microHD? Or even an old discarded microHD not wanted from which I could steal parts?
Register to hide this ad
I had an Amiko Mini HD SE with a similar problem - no output voltage, but it worked if power was applied to the other port of the C Band LNBF.
I remember tracing the voltage through the circuit and concluding that the problem was in the tuner chip, which was not available from Digi-key or Mouser. So I just discarded the receiver.
That's disappointing. I hate to discard things that have minor problems. The microHD has the best tuning indicator I've seen for dish orientation. It has a 10-segment time-division display that helps you get the dish oriented dead centre on the signal.
Reactions: Titanium
Have you checked in the Settings menu, to make sure LNB voltage isn't turned OFF? If I remember right, there IS a setting to do that, to use it as a slave.
Titanium
Revisiting this issue just because I have time and I'm curious to see if I can fix this unit for no practical reason other than the technical challenge.
Asking again if anybody has the schematic diagram? There are few enough parts that maybe I can figure out which is a voltage regulator chip by comparing part numbers with sources on the Internet. Changing it would not be easy but what's to lose?
Just to close this off....always go back repeatedly to check if a problem symptom exists while troubleshooting.
I don't really know why, but after opening and closing the box and poking around, I put it back together and tested in my system. Works like a charm! I now have a new old working satellite receiver. Maybe it's the oldest GSP microHD still in operation. Case closed.
If it happens again, you might check for a bad connection somewhere. Could be a solder joint. If that is the case, simply melting the solder often cures the problem.
Reactions: FTA4PA
Good advice. With age, solder joints can weaken. Especially near the F-connector which gets abused from screwing a cable on and off.
Reactions: FTA4PA
As much as I like the microHD, I find it not as good as my modern GT Media box. When I blind scan using the GT Media, it records all tps found whether strong enough to lock or not, or whether they are data tps. This is very useful to know exactly what you are receiving even if you can't view the channel. The microHD, like most receivers, will ignore those it can't lock or decode.
I still have 2 of them not currently in use. IIRC one of them didn't work with C-Band. Ku was fine. Then again I might have been having trouble with my LNBF or cabling at the time.
Reactions: FTA4PA
Whenever I am trying to fix a circuit board I look for dull or grainy looking solder joints, which means that they could be cold solder joints.
... I lost my Edision OS Mio last year. Worked with it for a little while, then got frustrated and snapped the board in half. I think it may have been a victim of static electricity when I touched the F-connector after walking across the carpet with socks on. I know better than to do that, but I forgot. Was an expensive mistake!
I tried to replace it with an Octagon SF8008. I found out that it has a Huawei SOC and so I never connected it to the internet. Then I sold it. Now I am using a cheap $13 receiver from Ali Express which is better than nothing, but not by much.
I should probably buy an Amiko Mini HD265 from Hypermegasat.....
Does anyone have a remote for a Micro HD? Gave the receiver to a friend who has moved on, he gave me back the receiver but couldn't find the remote for it.
Maybe there is a universal remote that might work?
-G.
-G.
The GEOSATpro DVR1100c, DSR100c, DSR200c and microHD used the same remote. Later models kept the same key codes, but changed layout and design.
Bet that Satellite AV still has NOS units for sale.
Reactions: Cham and Mr Tony
Hi Brian! Titanium
Yes you would know for sure. I'll see if I can get hold of "Dr Sat" and have him send me one.
Cheerz!
-G.
Good to hear there might be some of those remotes still around cuz I'm still using THREE of them on my 3 systems.
Lemmie know if you find them.
Just saying..............
OTHER GT Media V9 Prime DLNA Function
Titanium Satellite Titanium ASC1 Positioner Troubleshooting
