NBC mux on 99 Ku | SatelliteGuys.US
NBC mux on 99 Ku
freddylq
261
212
South Gate, CA
Is the NBC mux still up along with Montana PBS ? I don't get them anymore but I still get the national PBS's. Rescan doesn't get them either.
Larger antenna ? I like that idea !!!!
IIRC you have a 90 cm, and there was some vandalism/damage to it awhile back also? If you can afford it, you might consider upgrading to a 1.2m which should get you everything on 99 including all the wild feeds. There are dish resellers in CA that sell them, too, so if you have a truck or other means to pick it up, that could save you the shipping cost.
Yes except this is a new GeoSat dish and I didn't have issues with reception before. But I still like the idea of a bigger dish and will be on the look out for one possibly for C-band.
NBC mux and Montana coming in just fine at my location.
Are you actually able to receive video and audio? My TBS6985 card will let me scan the channels into Tvheadend but nothing will actually play. The PBS mux comes in fine so I don't think the dish is out of alignment, at least not by much.
What satellites are good to pick up with this?
99W NBC and PBS muxes
