Welcome to XenForo 2.3! | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,720
29,498
Newington, CT
Hi there and welcome back HOME to SatelliteGuys!
The upgrade to Xenforo 2.3 appears to have worked and in my testing all is appearing good. You may notice some new features and prompts which is part of t he new package.
I do see a bug where the icons in the editors are showing twice. I will fix that shortly (hopefully) :D
If you are having any issues before reporting them please clear your browsers cache.
I do have some running around to do before work tomorrow so I will be in and out all day but working on issues when I can.
Welcome home to SatelliteGuys!
I had proactively cleared my Cache before visiting. The Post Reaction item is stuck in Microsoft Vista mode ("You have selected to Like this post. Cancel or Allow?") 😉
The double icons in the editor is a template issue. If I use the default ui.x style (that this one is based off of) then the editor shows fine.
I have put in a ticket with UI.x for help on it, so I know what template(s) to revert. But even with double icons things are working.
Search index is still rebuilding but no longer showing an error.
Scott,
I'm not sure how they look on iOS or iPadOS yet, but if it is a pick one over the other, I like the bottom row icons over the old-style top row:
edit: but, now that I see it on my iPad, they do take up a little more vertical space, so I am fine with the previous style.
I kinda like this new software in that it doesn't automatically open any ignored content. It makes my life easier. I did have to change the color of my signature line font because it blended in with the dark style (which it didn't seem to do before).
Reactions: charlesrshell
While search is working, the predictive search feature (shows you matches while your still typing) is not working.
The author of the plugin knows this and is hoping to release an update this month for it.
I think for now I am done. Still waiting for a reply from UI.X on the double icons. But its Sunday and dont know if they workk on Sundays or not.. :)
Need a little help here
Access problem
