TitanTV guide | SatelliteGuys.US
TitanTV guide
ZetaMale
17,828
13,724
USA
Is anyone else experiencing incorrect times associated with programming? My grid is different also after upgrading Firefox. Computer clock is correct.
I can't log into it right now, it says it can't "find me". Then it says NOT to create a new account, or it'll interfere with "account migration during the upgrade"...
Hopefully they really are doing an upgrade, and will find my schedules
I was able to login, and channels are all correct. Did have to change the time setting to have DST turned on to have the programming correct and not out by an hour.
Don't like the new look, and seems to take longer to load. Also have to click on a program for the description (whereas before just had to hover over it) which also takes longer to load.
EDIT: Looks like some programming is still out of wack, while others are correct.
Well, they apparently lost my account, as I still can't log in. I've been trying to contact them, but they don't respond.
Error:
1001
Cannot find user for ID
If I try to recover it, I get this:
Error:
1018
Cannot find user for email
So, it wasn't my browser upgrade. Good. Hopefully they'll get it fixed.
The GEEK/NERDS strike again.
Anyway,I finally got back in by deleting the bookmark,then in history "forget about this site",then went to just "Titantv.com",entered username/password and was back in to the f'ed up mess they made of it.
Channels missing or misidentified,times screwed up etc etc etc.
Another case of old and crappy works / new and improved does not.
Reactions: Lone Gunman
Error:
1001
Error:
1018
Ok, they finally replied via email, and fixed my account. I'm back with my proper lineups, but BOY, it really SUCKS now! I can't imagine anybody calling this an "upgrade"...
This "upgrade" is garbage. Slower to load, messed up font sizes, and program descriptions are now missing. The spacing is all off, and the bottom half of text in cells is now being cut off. It appears to have been done to make TitanTV more usable on cell phones, but as always, the enshittification of the web in favor of cell phones has had a negative effect on tablets, laptops and desktops.
I've been dreading the changeover since the beta was announced.
Go into settings (the little gear near the lineup selection) and you will see various boxes to check or uncheck for grid settings and cell settings. Hope it works for you.
I'm running the old Titan app on an old iPad and it seems to be the same but I can't change anything. If I create a new lineup in my account on my computer it does not carry over to my iPad app. I'll live with it until it stops working completely but it's a pain.
Channelmaster Mount Hacking
Wondering what channels I can get with some old equipment.
