Received 350 software. Hopefully it fixes the fiasco from 348. Time will tell.
Sent from my SM-A326U using Tapatalk
They skipped to 348 which was broken, dropped back to 343 then jumped to 349 for not very long and now 350Wow H350 already, I haven't seen anything newer than H343 yet...
Did you get anything on what was updated for H350?They skipped to 348 which was broken, dropped back to 343 then jumped to 349 for not very long and now 350
No! And not happy about itDid you get anything on what was updated for H350?
Dish hasn't released a software version yet that isn't broken. So sick of constantly having to do their beta testing and dealing with this Mickey Mouse crap. Awful company. Can't wait for my contract to be up.They skipped to 348 which was broken, dropped back to 343 then jumped to 349 for not very long and now 350
It is up to Amazon to make their Prime app work with the Dish receiver software. They are not very good at that.and yet the problem only effects dish verison, cause version threw Roku is fine, the Roku verison of Netflix outputs DD fine threw Optical and Netflix threw Dish dont. and Roku version of Amazon video also dont have the lose of server connection issue, That and h3 dont have have these issue either apps, just the joey 4k does
Cause i can use the Roku verison of both and have no server connections issue with Amazon Video App. unlike with Dish verison and I can use Roku verison of netflix and actual get DD out of my Optical cable, but not threw dish verison. So obviously the issue isnt entirely Amazon or Netflix.
IF it was a amazon/netflix issue, why are the roku verison fine and problem i have with both amazon video and netflix on 4k joey dont happen on h3?
Please explain how it not dish fault there the one that make sure the app work with system in firstplace
I'm going to say the same thing I've been saying since Dish started offering apps on Hoppers - they're glitchy and problematic. Always have been, always will be.and yet the problem only effects dish verison, cause version threw Roku is fine, the Roku verison of Netflix outputs DD fine threw Optical and Netflix threw Dish dont. and Roku version of Amazon video also dont have the lose of server connection issue, That and h3 dont have have these issue either apps, just the joey 4k does
As the supplier of Dish receiver software, would it make sense for Dish to pull the Prime Video app from the H3 until it can be shown to work as solidly as does Prime Video on Roku? Deploying apps as part of Dish-provided software that are apparently not ready does not reflect well upon Dish. I thought the whole point was to get people to stay in the Hopper environment and not have to switch inputs, such as to a Roku in order to watch Prime and Netflix. If the stuff's not ready, pull it until it is ready. But do not rely on subscribers to be beta testers. Having said that, I think I'll go check out Prime on my H350-enabled H3 to see how well it works. I really have not had reason to do so, since Roku has always just worked.It is up to Amazon to make their Prime app work with the Dish receiver software. They are not very good at that.
Have you tried to uninstall the apps in in your Joey 4 and reinstall?The problem again dont happen on h3, it happen on joey 4k and those same apps work fine via my roku tv and even threw my consoles. the problem is simply on dish side.
The netflix problem i can ignore but the whole amazon video app wanting to show 1 maybe 2 shows/movies before autoplay stops on black screen, which new to 350 update, cause same issue where sever connections it lost cause if i mange to get to go back to amazon video home page interface it say exactly that server connections lost. The fact that that only happen on Joey 4k and Not H3 makes me thing it some dish has done. as this problem WAS fixed for months, but since 349 update this issue returned.
At this point I had all 4k joeys, switch/hubs and LNB + dish in my 2 h3 + 2 4k joey system, trying to fix other issues. so it not hardware but something dish has done
Only time i ever really force updates is when dish broke something in hope of them fixing it
He has a 4K Joey not a Joey 4. His issue is an Amazon app issue and has nothing to do with his receivers.Have you tried to uninstall the apps in in your Joey 4 and reinstall?
Is there a way Netflix & Prime can be uninstalled & reinstalled in the Hopper 3?He has a 4K Joey not a Joey 4. His issue is an Amazon app issue and has nothing to do with his receivers.
Limited time offer
