127 listed.How many channels is that, I'm too lazy to add them up.
I'm getting a signal presently of between 64-65 and it's heavy overcast today, but I also haven't seen any break-up or macro blocking yet today. What's typical signal strength? I'll check it again tomorrow, as it's supposed to partly sunny...That sounds like low signal. Call dish and get a tech out.
That sounds good. You may have a bad connection outside then that has gotten water in it.I'm getting a signal presently of between 64-65 and it's heavy overcast today, but I also haven't seen any break-up or macro blocking yet today. What's typical signal strength? I'll check it again tomorrow, as it's supposed to partly sunny...
It sprinkled a bit today, but I noticed no issues with the channels...I'll go outside tomorrow and check things out - I do that every summer anyway. Thanks!That sounds good. You may have a bad connection outside then that has gotten water in it.
During the later part of last year my 722's started acting up with lots of macro blocking and drop outs. I thought the receivers were just getting old. Last month when I replaced the 722's with a Hopper3, I discovered that despite the drip loops the RG6 connectors and barrels that went up to the LNB had almost corroded out. When I took them apart, the center copper conductor was almost corroded through and just broke off. They were, after all, almost 15 years old! When I replaced all of the RG6 connectors and barrels, the problem went away.That sounds good. You may have a bad connection outside then that has gotten water in it.
Anytime anyone would complain of intermittent signal loss or pixelation, my go to would be checking outside connections. In almost every case, corrosion and/or water damage was the culpritDuring the later part of last year my 722's started acting up with lots of macro blocking and drop outs. I thought the receivers were just getting old. Last month when I replaced the 722's with a Hopper3, I discovered that despite the drip loops the RG6 connectors and barrels that went up to the LNB had almost corroded out. When I took them apart, the center copper conductor was almost corroded through and just broke off. They were, after all, almost 15 years old! When I replaced all of the RG6 connectors and barrels, the problem went away.
So yes, check all of your connections all the way up to the LNB.
I believe PPV 505, 506, 508, 509, 510, 514 are already on 110. Got them on my guide.Yes - at least what I have down. However, the caveat - I can only see what I subscribe to. I don't subscribe to HBO, Cinemax, Showtime - so those channels were on 129 the last time they were in free preview.
The 3 HD transponders are TP 18, 24, 28.
Status Channel Type Network Now B 72 SD Value 129, TP 32 B 84 SD BuyTV 129, TP 23 B 102 HD Dish Studio 129, TP 24 B 104 SD Value (same as 72) 129, TP 32 B 157 HD NHL Network 129, TP 18 B 214 SD Weather Channel 129, TP 20 B 218 SD Binge 129, TP 26 B 240 SD Justice 129, TP 27 B 252 SD Law and Crime 129, TP 26 B 264 SD Impact 129, TP 32 B 282 SD Value 129, TP 32 B 283 SD BuyTV 129, TP 23 B 284 SD Rectv 129, TP 27 B 287 HD HSN 129, TP 18 B 294 HD AMC+ 129, TP 28 B 311 HD HBO West 129, TP 18 B 313 HD HBO Latino 129, TP 18 B 320 HD Showtime Too 129, TP 18 B 321 HD Showtime BET 129, TP 18 B 324 HD Showtime FamilyZone 129, TP 28 B 345 SD Encore Black 129, TP 26 B 346 SD Encore Classic 129, TP 27 B 347 SD Encore Family 129, TP 26 B 348 HD Encore Esp 129, TP 18 B 349 HD Dish Studio (same as 102 and 500) 129, TP 24 B 370 HD Circle 129, TP 28 B 378 HD Indieplex 129, TP 28 B 379 HD Retroplex 129, TP 18 B 380 HD MGM+ 129, TP 18 B 381 HD MGM+ Hits 129, TP 18 B 382 HD MGM+ Marquee 129, TP 18 B 386 HD Sony 129, TP 18 B 387 SD FMC 129, TP 26 B 390 SD Outside Television 129, TP 26 B 391 SD Fox Soccer Plus 129, TP 26 B 392 HD BEIN 129, TP 18 B 394 SD World Fishing Network 129, TP 23 B 398 SD FanDuel Racing 129, TP 23 B 399 SD FanDuel Racing 129, TP 23 B 402 HD ACC Network 129, TP 28 B 409 SD PAC 12 Network 129, TP 23 B 500 HD Dish Studio (same as 102 and 349) 129, TP 24 B 502 HD PPV Movies 129, TP 24 B 505 HD PPV Movies 129, TP 24 B 506 HD PPV Movies 129, TP 24 B 508 HD PPV Movies 129, TP 24 B 509 HD PPV Movies 129, TP 24 B 510 HD PPV Movies 129, TP 24 B 511 HD PPV Movies 129, TP 24 B 512 HD PPV Movies 129, TP 24 B 513 HD PPV Movies 129, TP 24 B 514 HD PPV Movies 129, TP 24 B 515 HD PPV Movies 129, TP 24 B 540 4K 4K Channel 129, TP 22 B 821 SD CLAN 129, TP 27 B 824 SD Baby 129, TP 27 B 826 SD WAPAA 129, TP 27 B 828 SD Univision West 129, TP 26 B 831 SD MLMDS 129, TP 26 B 839 SD Ant3 129, TP 27 B 841 SD NTEL 129, TP 26 B 842 SD Crcol 129, TP 27 B 846 SD DS Fam 129, TP 26 B 860 HD Bein Spanish 129, TP 28 B 861 HD BEIN (same as 392) 129, TP 18 B 863 SD MXCNL 129, TP 26 B 864 SD Csony 129, TP 27 B 865 SD Cine Latino 129, TP 27 B 883 SD Value 129, TP 32 B 891 SD TRS3 129, TP 27 B 998 SD Dish Business Info 129, TP 21 B 6002 Music SXM02 129, TP 29 B 6008 Music SXM08 129, TP 29 B 6009 Music SXM09 129, TP 23 B 6014 Music SXM14 129, TP 23 B 6015 Music SXM15 129, TP 20 B 6016 Music SXM16 129, TP 20 B 6019 Music SXM19 129, TP 23 B 6020 Music SXM20 129, TP 32 B 6021 Music SXM21 129, TP 23 B 6022 Music SXM22 129, TP 17 B 6023 Music SXM23 129, TP 23 B 6024 Music SXM24 129, TP 32 B 6025 Music SXM25 129, TP 32 B 6026 Music SXM26 129, TP 29 B 6027 Music SXM27 129, TP 17 B 6028 Music SXM28 129, TP 17 B 6029 Music SXM29 129, TP 23 B 6030 Music SXM30 129, TP 23 B 6032 Music SXM32 129, TP 23 B 6033 Music SXM33 129, TP 23 B 6034 Music SXM34 129, TP 23 B 6035 Music SXM35 129, TP 29 B 6036 Music SXM36 129, TP 29 B 6037 Music SXM37 129, TP 17 B 6038 Music SXM38 129, TP 17 B 6039 Music SXM39 129, TP 23 B 6040 Music SXM40 129, TP 29 B 6041 Music SXM41 129, TP 29 B 6042 Music SXM42 129, TP 29 B 6043 Music SXM43 129, TP 32 B 6044 Music SXM44 129, TP 29 B 6045 Music SXM45 129, TP 23 B 6046 Music SXM46 129, TP 23 B 6048 Music SXM48 129, TP 23 B 6049 Music SXM49 129, TP 23 B 6051 Music SXM51 129, TP 23 B 6052 Music SXM52 129, TP 23 B 6053 Music SXM53 129, TP 29 B 6054 Music SXM54 129, TP 32 B 6056 Music SXM56 129, TP 29 B 6057 Music SXM57 129, TP 29 B 6058 Music SXM58 129, TP 17 B 6059 Music SXM59 129, TP 23 B 6060 Music SXM60 129, TP 23 B 6062 Music SXM62 129, TP 23 B 6063 Music SXM63 129, TP 32 B 6064 Music SXM64 129, TP 23 B 6065 Music SXM65 129, TP 23 B 6066 Music SXM66 129, TP 23 B 6067 Music SXM67 129, TP 23 B 6068 Music SXM68 129, TP 29 B 6069 Music SXM69 129, TP 23 B 6070 Music SXM70 129, TP 23 B 6071 Music SXM71 129, TP 23 B 6072 Music SXM72 129, TP 29 B 6073 Music SXM73 129, TP 23 B 6074 Music SXM74 129, TP 29 B 6075 Music SXM75 129, TP 23 B 6076 Music SXM76 129, TP 29 B 9393 SD 3ABN 129, TP 21 B 9458 SD BuyTV 129, TP 23 B 9599 SD 129 Test Card 129, TP 21 B 540-1 4K 4K Channel 129, TP 22
yep! Once they start to corrode, just temperature changes can cause it to cut in and out, thus why a lot of people will say it's fine during the day (hotter, conductor expands) and doesn't work at night (colder, conductor retracts). Until eventually it just quits working completely.Anytime anyone would complain of intermittent signal loss or pixelation, my go to would be checking outside connections. In almost every case, corrosion and/or water damage was the culprit
This is good to know - I am going to make note on those 6 channels. I can only tune into them when they go "off air" overnight to see what transponder they are on. And even at that, the channels rotate when they go "off air" so I can't check them all at once.I believe PPV 505, 506, 508, 509, 510, 514 are already on 110. Got them on my guide.
I'll be heading outside shortly to check out all the connections and see if there are any issues that need attention. I'll report back my findings...Anytime anyone would complain of intermittent signal loss or pixelation, my go to would be checking outside connections. In almost every case, corrosion and/or water damage was the culprit
The free Winegard Signal Finder app is very useful for finding LOS issues using its augmented reality feature.And here's the report:
When the tech removed the old dishes late last year when he was installing the Hopper3/Joey3, he put up a new 3-LNB dish (for 110/119/129), new coax, new connectors, a new splitter - the whole works. I checked it out thoroughly and was pleasantly impressed. I hadn't checked it out in detail until this afternoon. Everything is new and secure, even the LNB connection. Again, I was very impressed.
So, now I'm suspecting the top of a vine maple tree that is in the LOS of the LNBs, but it's hard to tell (without getting up on a ladder to eyeball it better) if any of the leaves at the top of the tree are waving in-front of the LNBs when a breeze/wind comes up. I haven't seen any pixeliation or picture break-up or macro blocking for the past 3 days, but the weather has been nice here for the past two days and on Tuesday we just had heavy overcast with occasional sprinkles.
So, I'm thinking it wouldn't hurt anything to do some pruning of the upper part of that tree (yes, it's in my yard) and see if that helps...
Thanks! I'll give it a try.The free Winegard Signal Finder app is very useful for finding LOS issues using its augmented reality feature.
Winegard – TV Signal Finder - Apps on Google Play
Find satellite TV and free HDTV signals using our TV Signal Finder app with AR.play.google.com
Winegard® creates connectivity while at home, tailgating, trucking, or RVing by helping you view your favorite shows with this smart TV Signal Finder app with augmented reality. Finding the available TV satellites and free over-the-air HDTV towers for your geographic location has never been...apps.apple.com
Some of the Encore channels are still there. My locals are also still there. I also found the law and crime channel 252It looks like 129W is empty now. Can anyone confirm?
Here is what is left on 129 that I am able to see and based off of what others have shared with me. 122 entries, but not all of these things will be moving off of 129 (like SD Pac 12 Network, SD Weather Channel, 129 slate, etc) and there are some duplicate channels. My locals have already moved off, so I can only look at what is on the ConUS transponders.It looks like 129W is empty now. Can anyone confirm?
Channel | Type | Network | Now |
6022 | Music | SXM22 | 129, TP 17 |
6027 | Music | SXM27 | 129, TP 17 |
6028 | Music | SXM28 | 129, TP 17 |
6037 | Music | SXM37 | 129, TP 17 |
6038 | Music | SXM38 | 129, TP 17 |
6058 | Music | SXM58 | 129, TP 17 |
157 | HD | NHL Network | 129, TP 18 |
287 | HD | HSN | 129, TP 18 |
311 | HD | HBO West | 129, TP 18 |
313 | HD | HBO Latino | 129, TP 18 |
348 | HD | Encore Esp | 129, TP 18 |
392 | HD | BEIN | 129, TP 18 |
861 | HD | BEIN (same as 392) | 129, TP 18 |
214 | SD | Weather Channel | 129, TP 20 |
6015 | Music | SXM15 | 129, TP 20 |
6016 | Music | SXM16 | 129, TP 20 |
998 | SD | Dish Business Info | 129, TP 21 |
9393 | SD | 3ABN | 129, TP 21 |
9599 | SD | 129 Test Card | 129, TP 21 |
540 | 4K | 4K Channel | 129, TP 22 |
540-1 | 4K | 4K Channel | 129, TP 22 |
84 | SD | BuyTV | 129, TP 23 |
283 | SD | BuyTV | 129, TP 23 |
394 | SD | World Fishing Network | 129, TP 23 |
398 | SD | FanDuel Racing | 129, TP 23 |
399 | SD | FanDuel Racing | 129, TP 23 |
409 | SD | PAC 12 Network | 129, TP 23 |
6009 | Music | SXM09 | 129, TP 23 |
6014 | Music | SXM14 | 129, TP 23 |
6019 | Music | SXM19 | 129, TP 23 |
6021 | Music | SXM21 | 129, TP 23 |
6023 | Music | SXM23 | 129, TP 23 |
6029 | Music | SXM29 | 129, TP 23 |
6030 | Music | SXM30 | 129, TP 23 |
6032 | Music | SXM32 | 129, TP 23 |
6033 | Music | SXM33 | 129, TP 23 |
6034 | Music | SXM34 | 129, TP 23 |
6039 | Music | SXM39 | 129, TP 23 |
6045 | Music | SXM45 | 129, TP 23 |
6046 | Music | SXM46 | 129, TP 23 |
6048 | Music | SXM48 | 129, TP 23 |
6049 | Music | SXM49 | 129, TP 23 |
6051 | Music | SXM51 | 129, TP 23 |
6052 | Music | SXM52 | 129, TP 23 |
6059 | Music | SXM59 | 129, TP 23 |
6060 | Music | SXM60 | 129, TP 23 |
6062 | Music | SXM62 | 129, TP 23 |
6064 | Music | SXM64 | 129, TP 23 |
6065 | Music | SXM65 | 129, TP 23 |
6066 | Music | SXM66 | 129, TP 23 |
6067 | Music | SXM67 | 129, TP 23 |
6069 | Music | SXM69 | 129, TP 23 |
6070 | Music | SXM70 | 129, TP 23 |
6071 | Music | SXM71 | 129, TP 23 |
6073 | Music | SXM73 | 129, TP 23 |
6075 | Music | SXM75 | 129, TP 23 |
9458 | SD | BuyTV | 129, TP 23 |
102 | HD | Dish Studio | 129, TP 24 |
349 | HD | Dish Studio (same as 102 and 500) | 129, TP 24 |
500 | HD | Dish Studio (same as 102 and 349) | 129, TP 24 |
502 | HD | PPV Movies | 129, TP 24 |
511 | HD | PPV Movies | 129, TP 24 |
512 | HD | PPV Movies | 129, TP 24 |
513 | HD | PPV Movies | 129, TP 24 |
515 | HD | PPV Movies | 129, TP 24 |
218 | SD | Binge | 129, TP 26 |
252 | SD | Law and Crime | 129, TP 26 |
345 | SD | Encore Black | 129, TP 26 |
347 | SD | Encore Family | 129, TP 26 |
390 | SD | Outside Television | 129, TP 26 |
391 | SD | Fox Soccer Plus | 129, TP 26 |
831 | SD | MLMDS | 129, TP 26 |
841 | SD | NTEL | 129, TP 26 |
846 | SD | DS Fam | 129, TP 26 |
863 | SD | MXCNL | 129, TP 26 |
240 | SD | Justice | 129, TP 27 |
284 | SD | Rectv | 129, TP 27 |
346 | SD | Encore Classic | 129, TP 27 |
821 | SD | CLAN | 129, TP 27 |
824 | SD | Baby | 129, TP 27 |
826 | SD | WAPAA | 129, TP 27 |
839 | SD | Ant3 | 129, TP 27 |
842 | SD | Crcol | 129, TP 27 |
864 | SD | Csony | 129, TP 27 |
865 | SD | Cine Latino | 129, TP 27 |
891 | SD | TRS3 | 129, TP 27 |
294 | HD | AMC+ | 129, TP 28 |
370 | HD | Circle | 129, TP 28 |
402 | HD | ACC Network | 129, TP 28 |
860 | HD | Bein Spanish | 129, TP 28 |
6002 | Music | SXM02 | 129, TP 29 |
6008 | Music | SXM08 | 129, TP 29 |
6026 | Music | SXM26 | 129, TP 29 |
6035 | Music | SXM35 | 129, TP 29 |
6036 | Music | SXM36 | 129, TP 29 |
6040 | Music | SXM40 | 129, TP 29 |
6041 | Music | SXM41 | 129, TP 29 |
6042 | Music | SXM42 | 129, TP 29 |
6044 | Music | SXM44 | 129, TP 29 |
6053 | Music | SXM53 | 129, TP 29 |
6056 | Music | SXM56 | 129, TP 29 |
6057 | Music | SXM57 | 129, TP 29 |
6068 | Music | SXM68 | 129, TP 29 |
6072 | Music | SXM72 | 129, TP 29 |
6074 | Music | SXM74 | 129, TP 29 |
6076 | Music | SXM76 | 129, TP 29 |
72 | SD | Value | 129, TP 32 |
104 | SD | Value (same as 72) | 129, TP 32 |
233 | SD | Superstation | 129, TP 32 |
234 | SD | Superstation | 129, TP 32 |
235 | SD | Superstation | 129, TP 32 |
236 | SD | Superstation | 129, TP 32 |
264 | SD | Impact | 129, TP 32 |
282 | SD | Value | 129, TP 32 |
883 | SD | Value | 129, TP 32 |
6020 | Music | SXM20 | 129, TP 32 |
6024 | Music | SXM24 | 129, TP 32 |
6025 | Music | SXM25 | 129, TP 32 |
6043 | Music | SXM43 | 129, TP 32 |
6054 | Music | SXM54 | 129, TP 32 |
6063 | Music | SXM63 | 129, TP 32 |
This goes to show we are very close to 129 being gone. Not many highly watched channels left on 129. Dish did a pretty good job of getting the main ones off. I am surprised that NHL Network and ACC Network didn't get moved in an earlier shift given how they are in the lower packages coupled with higher viewership. (especially since the Stanley Cup playoff were going on full force during the transition and there was some baseball on ACC Network)I had a work order the other day that was set for western arc and it only showed setting up 119/110.
I've seen those myselfI had a work order the other day that was set for western arc and it only showed setting up 119/110.
Limited time offer
