Can the 40.0 remote be used with a Hopper 3 in IR mode (and yes I know your have enable IR reception)? And if not, are there any other Dish remotes that will work with a Hopper 3 as an IR remote?
The 40 remote works perfectly with the Hopper 3. If you have a Hopper+ with that H3 there are some buttons that do not work.Can the 40.0 remote be used with a Hopper 3 in IR mode (and yes I know your have enable IR reception)? And if not, are there any other Dish remotes that will work with a Hopper 3 as an IR remote?
The 40.0 works natively via UHF, I dont believe you can use it in IR mode for receiver commands. If you enable IR mode on the receiver you can use any dish made IR remote however, I've gone all the way back to the 1.5 and it works with both of my non-plus Hopper3's.Can the 40.0 remote be used with a Hopper 3 in IR mode (and yes I know your have enable IR reception)? And if not, are there any other Dish remotes that will work with a Hopper 3 as an IR remote?
Just to clear, the 40.0 remote will control a Hopper 3 via IR and not just UHF, correct?The 40 remote works perfectly with the Hopper 3. If you have a Hopper+ with that H3 there are some buttons that do not work.
How did you pair the older remotes to the Hopper 3? I tried the old IR 5.3 and IR/UHF 6.3 remotes that came with my VIP722s and couldn't get either to work with the Hopper 3.The 40.0 works natively via UHF, I dont believe you can use it in IR mode for receiver commands. If you enable IR mode on the receiver you can use any dish made IR remote however, I've gone all the way back to the 1.5 and it works with both of my non-plus Hopper3's.
The 40 remote controls the Hopper via UHF only. It will also control a TV via IR.Just to clear, the 40.0 remote will control a Hopper 3 via IR and not just UHF, correct?
And I will likely never have a Hopper+.
OK, then that remote won't work for me. Thanks.The 40 remote controls the Hopper via UHF only. It will also control a TV via IR.
Why is that?OK, then that remote won't work for me. Thanks.
Which universal remote are you using? If it is a Harmony it can be programmed for the Hopper via the Logitech app.My entertainment system is all based around IR repeaters and emitters. I need an IR remote to train my existing universal remote to control the Hopper 3. Once I train my universal remote, the Dish remote will no longer be used.
Yes, but there's no reason for itJust to clear, the 40.0 remote will control a Hopper 3 via IR and not just UHF, correct?
You don't pair them, like you do with a remote that comes with a Hopper, 40, 50, 52…How did you pair the older remotes to the Hopper 3? I tried the old IR 5.3 and IR/UHF 6.3 remotes that came with my VIP722s and couldn't get either to work with the Hopper 3.
Pretty much what HipKat mentioned above, hold the white/clear sat button until all the buttons on the top light up, once they are let go, press 1 then # on the number pad. Just going to add that the 6.3 needs to be in IR mode and the key at the bottom (the plastic insert) needs to be set to tv1 (green) as well.How did you pair the older remotes to the Hopper 3? I tried the old IR 5.3 and IR/UHF 6.3 remotes that came with my VIP722s and couldn't get either to work with the Hopper 3.
If you are already paired for a 722 then you just teach it from that. It's the same functions.It's an older, now discontinued, MX-500. I'm trying to get the Hopper 3 integrated into my entertainment system with the minimum of change. And using an IR/Hopper remote to train my existing MX-500 is the simplest means right now.
However, the MX-500 is a pain in the butt to program. And I wouldn't be adverse to updating to a newer, more capable universal remote in the future. So I'm curious to know exactly which Harmony remote you are referring to.
But it's just right now that converting to a new universal remote would be a lot of work that I'm trying to avoid in the short term.
Currently my IR system is configured for:
2 VIP722
1 now Hopper 3 (used to be an old VIP625)
1 AV Surround Sound tuner receiver
2 65" TVs
2 Apple TVs
1 DVD player
1 VCR (really)
2 Fireplaces
1 Front door camera
and the whole home lighting system.
This also includes a couple of custom bridge devices I built to bridge to some devices.
Additionally, once the Hopper 3 is fully integrated, I will be replacing the VIP722s with Joeys to retire the old DPP satellite configuration.
That's a lot of retraining/redesign work that I want to put off until I get everything fundamentally working, and know it will all pass the WAF test.
Same remote that comes with all Hopper equipment, the 54.x and yes, a Joey can us IRRelated questions. What remote usually comes with a Joey3, and can a Joey3 use an IR remote?
Limited time offer
