KAB SatelliteGuys Master Original poster Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,330 6,332 Fishers, IN Apr 19, 2023 #1 Does it work with the same WAP as the WJ2? Have not seen anything else available.
charlesrshell SatelliteGuys Crazy Lifetime Supporter Jan 14, 2006 11,248 5,981 O'Fallon, IL Apr 19, 2023 #2 KAB said: Does it work with the same WAP as the WJ2? Have not seen anything else available. Click to expand... Yes
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,722 29,501 Newington, CT Apr 19, 2023 #3 Yup the same. And I have used them both with the first gen and second gen access point without issue. Reactions: TheKrell, Bobby and charlesrshell
KAB SatelliteGuys Master Original poster Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,330 6,332 Fishers, IN Apr 23, 2023 #4 I don't give a D about android TV, not in the slightest. But does the WJ4 perform notably better than the J2 in terms of speed and UI? Bottom line, take away Android, would I be glad I got it? Reactions: larry55
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,722 29,501 Newington, CT Apr 23, 2023 #5 Yes for the most part. However the trick play however is not as fast. Reactions: charlesrshell
KAB SatelliteGuys Master Original poster Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,330 6,332 Fishers, IN Apr 24, 2023 #6 Scott Greczkowski said: Yes for the most part. However the trick play however is not as fast. Click to expand... Well, that's a deal breaker.
