Just got dish setup yesterday, however I am unable to set up the side input button to control the TV's input? I've got the remote setup to turn the TV on and off and to control volume on my soundbar.
Press TV side button & then the side Input button.Just got dish setup yesterday, however I am unable to set up the side input button to control the TV's input? I've got the remote setup to turn the TV on and off and to control volume on my soundbar.
Can you elaborate more on this? SorryPress TV side button & then the side Input button.
Sorry my bad I see what your saying, this does not work.Can you elaborate more on this? Sorry
What Dish remote control are you using?Sorry my bad I see what your saying, this does not work.
I believe it's the 54.0. That's what the batter cover saysWhat Dish remote control are you using?
Did you set up your remote in settings, remote control menu?I believe it's the 54.0. That's what the batter cover says
The tech did.Did you set up your remote in settings, remote control menu?
Go into settings remote control menu and make sure what the tech setup is correct.The tech did.
How am I supposed to know what's right or wrong?Go into settings remote control menu and make sure what the tech setup is correct.
Can you send a screen shot of your remote control menu settings?How am I supposed to know what's right or wrong?
That's not all of the settings. While in the remote control menu, use the down arrow key to scroll down and then send a pic.Attached
Try this.That's not all of the settings. While in the remote control menu, use the down arrow key to scroll down and then send a pic.
Turn Limited Mode to Off. Then back out, on the side of your remote press the TV button and then the Input button and see if your TV inputs show up.Try this.
Lol, that got it! Thanks a ton! I knew I wasn't crazy as I have had dish in the past and knew this could be done.Turn Limited Mode to Off. Then back out, on the side of your remote press the TV button and then the Input button and see if your TV inputs show up.
Limited time offer
