DISH Makes TV Easy with New Hopper Plus™ | Page 12 | SatelliteGuys.US
As you will notice the 40.0 remote does not work well with it. They want you to use the DISH Vice Remote with it and ONLY the Dish voice remote.
My wife HATES the Dish 54 remotes but its the only way she has full access to her recorded shows.
Still same config. DPH42 switch to Duo Hybrid Hub then from Hub to both Hopper 3s.
Keep us posted on how he hopper + is performing and if it resets or freezes and if it is producing a better PQ. I need PIP and multi view so the Hopper + is disconnected and never tried to reconnect it to see how it affected the 2nd Hopper 3. Glad to hear so far you have no issues
Just for grins you might try to connect one of your new Joey 4s to the Hopper 3 without the Hopper+. I know the Joey 4 will work without a Hopper+ so it just might work. You are not going to break anything. If it doesn't work simply go back to the original configuration.
Will give it a try tomorrow Bobby. The Commander is home now!!
  • Haha
Reactions: MikeD-C05 and Bobby
We love them. It is my spare bedrooms that the 40.0 comes in handy for kids and guest. They go into a state of shock when they try to use the 54.0. I was just so happy that the 2nd Hopper 3 still worked (for now) and the 40.0 remotes work for the most part. I will probably swap out most of the 40.0s now that I have lots of spare 54.0 remotes. My Commander just noticed the much better picture quality. Yehaa.
The 40.0 is my absolute favorite! ALL the others are cumbersome and hard for me to find buttons. The only exception is voice searching is so much easier than hunt and pecking!
Reactions: charlesrshell
My commander just spoke! She enjoys the better PQ on the H+ but she doesn't like the remote controls sluggish commands. Response time is slower when she presses the buttons on her 54.0 than it use to be with the H3. Also when she skips forward a recording the picture is slow to get going again. Anyone else notice this with the H+? Is this something that will get better as she (H+) settles down?
  • Sad
Reactions: TheKrell
Thanks. Is the picture quality better on the the J4 and WJ4 as well?
LNBF for Wally with 1000.2 dish
Odd Showtime Offers
