Picked up a couple of Minnesota TV stations in Carrollton, MO, this morning (8/5/2022) | SatelliteGuys.US
Route66Fan
232
145
Missouri
This morning (8/5/2022), I received a couple of TV stations from Minnesota (KCCW-TV, Walker, MN & WUCW-TV, Minneapolis/Saint Paul, MN.). KCCW-TV, at about 525mi, is, as far as I can remember, the farthest TV station I've received via tropo with an HDHomerun tuner (KHSV-TV, Las Vegas, NV (1197mi) is the farthest that I've received, with a HDHomerun tuner, via E-skip.).
Interesting that you got KCCW as KEYC Mankato is closer to your location (and also on RF12). It's pretty much between KCCW and your location
But then again KEYC was at lower power (or some interference) last night (it's my local CBS/FOX station)
KCCW may have been interfering with them. I have also picked up KEYC in the past.
I sometimes do a scan in the early morning this time of year. It often fills most of the channels with stations from MN, ND, sometimes SD, and WI. Not uncommon to get 100 channels, but most are duplicates of maybe 15 actual RF channels that happen to have the same programming at different sites.
I think DXing actually works better with digital signals than analog. Somertimes I get DX stations coming in so well they overpower some of the locals.
Can certainly tell when the band drops out, sometimes within 5 minutes it all disappears. Best time seems to be about an hour after sunrise up here, but evenings can be good too.
More morning troposphere from Carrollton, MO (8-1-2022)
OTA ground connection
