Where did you get it?With the excitement, I went out and purchased a HdHomeRun Connect 4K ATSC 3.0 Tuner. Just hooked it up and did a scan, hoping to find them testing and nothing yet.
But I will keep on checking.![]()
The old signal will remain the old signal for a few years... then the old signal will go away and everything will be 3.0 only.So you will get the same "old" signal, but will it be more robust like the 3.0?
Yeah, when a station begins broadcasting in 3.0, they have to keep broadcasting on 1.0 for at least five years before they can voluntarily shut down the 1.0 signal. But a couple things would need to happen before a station would consider shutting down their 1.0 signal.The old signal will remain the old signal for a few years... then the old signal will go away and everything will be 3.0 only.
Some newer 4K sets, like my Samsung QN90A, has a built in ATSC 3.0 tuner.
I don't like it already bc it means I have 2 replace all my gear.Yeah, when a station begins broadcasting in 3.0, they have to keep broadcasting on 1.0 for at least five years before they can voluntarily shut down the 1.0 signal. But a couple things would need to happen before a station would consider shutting down their 1.0 signal.
First, pay TV distributors (e.g. Comcast, Charter, etc.) would need to have agreed to carry their 3.0 signal in lieu of their 1.0 signal.
Second, enough of their viewers who watch via OTA antenna would need to have shifted from watching their 1.0 signal to their 3.0 signal, which of course requires them buying a separate 3.0 tuner (currently priced at $200 and up) or, more likely, having purchased a new TV with a 3.0 tuner built-in. But without a mandate from the FCC for new TVs to include those tuners, and without any kind of government-subsidized tuner giveaways as happened with the analog-to-digital switchover several years ago, I'm skeptical of how widely ATSC 3.0 will be adopted by consumers.
You can buy the stand alone tuner.I don't like it already bc it means I have 2 replace all my gear.
I know. I'm replacing standalone tuners w/ standalone tuners.You can buy the stand alone tuner.
You are using a stand alone ATSC 1.0 tuner for ota reception?I know. I'm replacing standalone tuners w/ standalone tuners.
Yup.You are using a stand alone ATSC 1.0 tuner for ota reception?
Let's face it, external OTA tuners (whether in a network tuner like HD HomeRun, or an OTA DVR like Tablo or TiVo) are pretty niche. I have an HD HomeRun and it's great, it lets me watch live and recorded OTA TV through my Apple TV 4K box. But I can't ever see devices like that becoming mainstream. Just don't see many folks purchasing an external ATSC 3.0 tuner unless they were cheap and getting built directly into popular streaming devices like Roku, Fire TV, etc.I don't like it already bc it means I have 2 replace all my gear.
Does the FCC intend to subsidize converter boxes like they did for the digital transition?I know. I'm replacing standalone tuners w/ standalone tuners.
Where's the incentive for people to spend money to get something they perceive as little or no value added? I fear this will be like 3D all over again, or theater quality sound. They may remain niche products, as NashGuy said. Some think we may never have gone to HDTVs at all except that the screen was BIGGER and CHEAPER than old CRT TVs were. I have a good friend who retains 3 old 19" Sony CRT TVs and refuses to upgrade to anything better. I even handed him a small 24" HDTV as well as a FireTV STick, neither of which he has even tried out once. I think he's nuts. But he just doesn't use his TV for much at all. As long as his Sony's refuse to die, he keeps them around.Nope
Yeah, but how many will think it's beneficial to spend a couple hundred bucks on a converter box, or upgrade their otherwise well-functioning TV just for slightly better reception and slightly better picture?The biggest benefit I can see is a more robust signal allowing for better, more consistent reception. Here in CT we have a lot of hills. Not big ones but enough to knock the signal down to unreceivable in places.
The way I read it, the signal will be more robust even if you are using a 1.0 tuner.Yeah, but how many will think it's beneficial to spend a couple hundred bucks on a converter box, or upgrade their otherwise well-functioning TV just for slightly better reception and slightly better picture?
And that will be great. WTNH is not solid for me with my Dish OTA setup. I hope that improves....The way I read it, the signal will be more robust even if you are using a 1.0 tuner.
Can you pick up 40 out of Springfield?And that will be great. WTNH is not solid for me with my Dish OTA setup. I hope that improves....
No. WTNH averages about an 80 signal strength on my Dish receiver. It's good most of the time, with occasional dropouts.Can you pick up 40 out of Springfield?
Limited time offer
