Signal meter for local channels | SatelliteGuys.US
Accurate compared to what? My Tivo reads different OTA signals than my DISH does but both are consistent. So if the TIVO shows 68% the DISH will show about 60%. When I put a signal meter on (it's been awhile since I have) the DISH was a little closer to the meter signal if that's what you mean.
Reactions: charlesrshell
I do not believe we are looking at true signal strength, but rather something more like an inverse error rate. So 100% should correspond to zero errors.
I do believe, as Sam said, that excess signal strength can overload the input stages of any tuner and cause the error rate to go up. But whether too low or too high, the "100%" reported by mopardude should go down. I think his 1 sec dropouts are caused by some other issue.
Reactions: Foxbat
Dishmaker dual
DPH42 LNB inputs - need all four populated?
