Samsung suppory | SatelliteGuys.US
Samsung suppory
Megifl
2
Florida
I have a Directv hbomax subscription at 1 home - works fine. I have dish nw at 2nd home with 2 Samsung tvs. 1 supports my hbomax subscription fine. Other TV says hbomax is not supported not supported. Any suggestions? Thx..
Are the ones at the 2nd location Smart TV's ?
If not, how are you supplying them the HBO Max app ?
Your credentials (same credentials) should work at both locations.
Hi thanks, both are smart tvs. The one that will not show HBO max does not have directv as a sign in option, and I can't find the actual TV app in the Samsung store... I do have a Google browser and an internet bar to type in a web page but can't seem to figure out which url to use for my hbomax from my directv.
Even if it worked on that TV browser, you might find life a bit easier if you just picked up an inexpensive Roku Stick or Firestick for HBOMax (and any other streaming apps) on that older Samsung TV. Less than a week until Prime Day, so you can bet Firesticks will be on sale on Amazon.
TiVo boot loop
