hr24 500 slimlne dish install | SatelliteGuys.US
Rainy99
91
16
USA
Ok here we go. Equipment is hr 24 500, slimline dish, sls 3 lnb and sl5 lnb. Both lnb are swm. I can only get 80% on 101 transponder 1. Have tried both lnb,s, reset receiver, ran new cable and tried two different odu power supplies. I get my best reception with the sl5 lnb but cannot peak above 80% on transponder 1 one the 101 satellite. I am running out of options. The 99 and 103 sats have very low numbers. Tried changing az and elevation all over the place. What should be my next step?
What do you get on other 101 transponders? What are you using to peak the dish? What are some exact numbers on 99 and 103? Can you post a picture of your completed dish with closeup of LNB/arm interface?
101 gives me transponder 4 95 transponder 1 68. I am using the receivers signal strength to set dish. 99 and 103 numbers are low 30
If both 99 and 103 are off then I suspect your skew and/or elevation are a bit off. Without a meter it can be tricky to dial in a dish.
skew is set to 70, that is what dishpointer says when i use my location. I am inclined to think the pan is warped.
Directv Select Package Pricing
COAX to Ethernet Question
