LNB question? | SatelliteGuys.US
LNB question?
hansokl
65
2
Atlanta
Good afternoon!
I'm curious on the difference between the 3D2RBLNBR0-01 and the 3D2RBLNBR0-02 LNBs.
Im assuming just a newer model but does anyone know?
Good afternoon!
More than likely your thought is correct ...
It's either a newer model or a different manufacture, but I'm leaning towards the newer model.
Thanks! It looks different but works fine. Just was curious.
There's a -14 for LNBs but I don't know if it is Andrew or Calamp. Neither have made LNBs for years so it is irrelevant except for old KaKu LNBs.
I don't even know their mfr cods any more but CalAmp did make dishes, LNBs and mounts early on. Andrew had a very capable team designing one of the first KaKu systems but could never get some mechanical specs to pass and therefore were never turned on to supply dishes and mounts.
I wish I could go into detail about the Andrew dish and mount but those pesky non disclosure agreements get in the way. I can say if they had met specs and were turned on to produce dishes and mounts the alignment procedure we have today would be radically different. They had a brilliant consultant on the team with some very impressive analysis programs and ideas but whoever was responsible for understanding and fixing some mechanical problems never came through.
I wish there was a forum here for ex DirecTV employee stories, I got a boat load of um.
From the last report I got on it. The "-14" LNB mfr. code was for a company called "MTI."
For "Microelectronics Technology Inc." in Taiwan I think ...
Sent from my LM-V600 using Tapatalk
There was always a lot of consolidation that industry so maybe MTI was later purchased by Andrew or Calamp, or the other way around?
Local Ads on National Channels? Since When?
AM21 maybe gone bad?
