The Joey with my hopper 3 skips ahead when fast forwarding a recording. It only happens in standard definition, HD no problem. If I play it on the hopper, the recording plays fine. Anyone else have this problem?
Same problem. Very badHello, bobdee. We have been seeing reports of this issue affecting the Joeys for a number of customers. We would be happy to take a further look into this issue and get it reported. To get that reported, please reach out to our chat team here.
I watch METV reruns from time to time and the trick play is pretty much useless. I never thought about it being an SD channel issue, but now that I think about it, METV is probably the only SD channel that I do watch.My Joey 3 does it with HD material sometimes. I don't watch SD channels so I have no experience with that. I have paused shows, then later trying to FF through commercials it will suddenly skip ahead to some point later in the show. I then have to rewind to get back to the point where I was originally. It is kind of annoying. It doesn't happen every time, but often enough.
I'm watching something I recorded around 5 years ago. It was transfers to external drive and back to the Hopper. Trick play doesn't work at all on the Joey. Backwards goes into the future and forward goes to the present other unpredictable behavior. I just use fast forward and reverse. It's all I can do.I watch METV reruns from time to time and the trick play is pretty much useless. I never thought about it being an SD channel issue, but now that I think about it, METV is probably the only SD channel that I do watch.
Limited time offer
