Channel 293, It's squeezed into a 4x3
I had to stretch it. But now I suppose everything is stretched (it did)Channel 293, It's squeezed into a 4x3
When did they add H&I at this slot?
Sent from my SM-G965U1 using Tapatalk
IIRC Comet wasn't HD when it was first addedNot even 2 hours ago, wished it was the HD feed like they did with Comet.
14 changes seen 9/2/20 at 3:15pm ET (v20)
Channels Now Available
293 HERIC Heroes & Icons 110° TP 1 SD Hidden - AVAILABLE
293 HERIC Heroes & Icons 72.7° TP 9 SD MPEG4 Hidden - AVAILABLE
That is correct. Here are the relevant uplink reports:IIRC Comet wasn't HD when it was first added
Have H&I is actually welcome because it's the one reason I put up the antenna. And it's on VHF 2 here so it's hard to get consistently.
I wish Dish software would remember the stretch per channel. H&I OTA stretches by default. I wouldn't mind them showing the original 4x3 but they don't. So Dish should stretch it by default.
Well since H&I and MeTV are both Weigel properties perhaps they will switch to HD at a later date and it's no surprise to me that the H&I feed is anamorphic just like MeTVThat is correct. Here are the relevant uplink reports:
289 COMET Comet TV 119° TP 8 SD Hidden – AVAILABLE
289 COMET Comet TV 61.5° TP 1 SD MPEG4 Hidden – AVAILABLE
9689 COMET (289 HD) Comet TV 129° TP 28 HD Hidden – AVAILABLE
9689 COMET (289 HD) Comet TV 61.5° TP 15 HD Hidden – AVAILABLE
Uplinks Removed
289 COMET Comet TV removed from 119° TP 8 (SD Hidden)
289 COMET Comet TV removed from 61.5° TP 1 (SD MPEG4 Hidden)
Note that when the HD feed launched, they also removed the SD feed. It took Dish a few months to realize that they still needed the SD feed for Western Arc, so they added it back:
289 COMET Comet TV 110° TP 16 SD Hidden – AVAILABLE
But their big draw is tweeting #allstartrekJust about everything they have can be seen on Netflix or Prime.
But if Star Trek is like other shows on All Access they do not show every episode.If want to watch Star Trek, any version of it, I simply go to CBS All Access and stream it.
What they do on H&I is advertise Twitter #allstartrek as a way to group tweet all the classic Star Trek series. They show them in episode order. They repeat the cycle every few months.But if Star Trek is like other shows on All Access they do not show every episode.
Actually they do, I just checked...But if Star Trek is like other shows on All Access they do not show every episode.
Limited time offer
