ZetaMale SatelliteGuys Master Original poster Pub Member / Supporter Aug 2, 2009 17,940 13,852 USA Sep 1, 2020 #1 Anyone know where I can get one of these? I wish I hadn't lost it. Obviously, it's for mounting an HH motor (SG9120) to a pole. Attachments DSCN1544.JPG 287.6 KB · Views: 230 DSCN1545.JPG 266.6 KB · Views: 244
primestar31 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Mar 15, 2005 14,873 17,581 Beta Omicron Delta III Sep 1, 2020 #2 Get a length of U-channel (or C-channel) from Home Depot, cut to length, hacksaw out a "V" shape in it, and drill some holes. Or, try your local hardware store, perhaps they have some large U bolts with one of those as part of it.
I Inclined Orbit SatelliteGuys Pro Jan 2, 2018 466 293 Los Angeles Sep 1, 2020 #3 Ebay has lots of those parts and they will usually come with a U bolt. I've bought many of them for cheap over the years. Search on "mast clamp" or "mast U bolt", etc.
Larry1 SatelliteGuys Pro Aug 24, 2005 1,594 138 Port Hope, ON Canada Sep 1, 2020 #4 Look in your hardware/auto parts store for a muffler clamp and you should be able to find something to replace it. There are lots of sizes available.
ZetaMale SatelliteGuys Master Original poster Pub Member / Supporter Aug 2, 2009 17,940 13,852 USA Sep 1, 2020 #5 Larry1 said: Look in your hardware/auto parts store for a muffler clamp and you should be able to find something to replace it. There are lots of sizes available. Click to expand... I haven't been able to find one large enough - at least nothing in stock. Not to mention this is a metric size.
RimaNTSS SatelliteGuys Pro Aug 9, 2013 896 962 Riga Sep 1, 2020 #6 johnnynobody I have several such parts lying around. I can send you a couple if you wish. Reactions: primestar31
