Sous Vide | Page 6 | SatelliteGuys.US
Sous Vide
Cooked 2 seperate qt bags with diced small potatoes, bell pepper, 1 slice owens hot sausage apiece and 1 strip bacon diced into both with a little butter at 195F for 2 hours or so. Then mixed 2 eggs into each and scrambled up with a fork, stirring occasionally till done.
Made burritos with some sharp cheddar cheese, good breakfast this morning...
Hmmm. Sounds good. I might try something similar for supper later this week, but using mild sausage.
I gather the potatoes and bell pepper went in raw, but the bacon was cooked?
Cooked 2 seperate qt bags with diced small potatoes, bell pepper, 1 slice owens naturally sausage apiece with 1 strip bacon diced into both, added a little 80/20 hamburger meat with a little butter at 195F for 2 hours or so. Then mixed 2 eggs into each and scrambled up with a fork, stirring occasionally till done.
Made burritos with some sharp cheddar cheese for the weeks breakfasts (mixed them up with a few survivors of last week for variety)...
Reactions: navychop
Do you wrap in wax paper or similar and then freeze? Or what is your burrito prep method?
I will post a review later, but I have both Joule and Anova. I regret the Anova purchase. More difficult to work with, especially as the water depth requirements are much stricter. Quite limiting on what containers you can use. Deep only.
I have the Bluetooth version of the Anova purchased a few years ago. I have used a six-pack-sized Coleman cooler to hold the water bath and the depth is just right, as is the thickness of the walls. I have used a piece of dense-cell foam as a top to control heat-loss.
The small size of the cooler is a bit limiting. I'm trying to figure out a system of suspending the food bag in the bath so it stays submerged but isn't in contact with the sides or bottom. My picture shows a small rack and a wooden clip to hold the turkey burgers under.
Reactions: dfergie
Quick and Easy
Blackstone Grill
