KBRO-LD is going to ATSC 3.0 in 8-1-20 | SatelliteGuys.US
RF-LO channel 2 at 3 Kw? Will anybody be able to actually receive that?
That will be interesting.
The time interleaving of ATSC 3.0 should overcome some of the low band noise disadvantages of 8 VSB. How much remains to be seen.
The station may also opt for more robust modulation scheme with lower bandwidth for an even further improvement. The picture quality will be fine due to the low bitrate of HEVC.
Someone asked if anyone is going to be able to watch KBRO-LD with 3 kw on channel 2. Well, KQRO is running ATSC 1.0 on channel 2 with 3 kw and i receive a solid signal from it 55 miles away from the transmitter site. ATSC-3.0 is supposed to be better than ATSC 1.0, too!
Larry
You're also a professional and you own really good antennas ;)
VHF Low Reception
Trying to upgrade an existing antenna setup
