I was curious if I could check in easy way if a dish was still pointed correctly, (and its LNBF might be damaged), WITHOUT REMOVING (UNSCREWING)
THE EXISTING LNBF.
Assuming that I have another, tested LNBF and any small receiver.
Reflector (made of metallized paper) was glued to a piece of sponge which had 45 degree angle.
The sponge has a hole which fits snugly on existing LNBF.
Second LNBF was placed next to 45 degree "mirror" - and it received signal, unfortunately, much weaker, (Q = 30%).
Now, the existing LNBF cable can be unscrewed, and small testing receiver connected to existing LNBF.
If there is no program, it means the existing LNBF is damaged.
Maybe, if I used better reflector, not paper, but thin aluminum plate, the reflected signal could be better... I have to test it later.
If there is no reflected signal on added LNBF, it could indicate that the dish has moved from its original position.
Probably, moving the added LNBF around a little, might catch the program and thus indicate in which direction the dish shifted.
This will not work if the dish has moved more than a few degrees.
10 photos, some annotated, follow.
Cheers, polgyver
THE EXISTING LNBF.
Cheers, polgyver
