what is orby satellite? | SatelliteGuys.US
Mazboy
4
north america
I just came across this Orby Satellite....who is it exactly? Is it a Dish/Direct/Shaw satellite system that is just contracting with one of those systems?
The reason I am asking is I have Winegard Travler 1000 on my RV and I would just change it to whatever satellite system Orby uses.
Orby is an independent subscription service carried on 116.8w KU band. No affiliation with other subscription services. This satellite transmits a linear polarity signal and is not compatible with the Winegard Travler 1000 which uses circular polarity.
You never mentioned that your Winegard Traveler was doing Shaw. That is a linear polarized service like Orby. If the Winegard can be programmed to point at Orby it should work just fine.
Reactions: EmCommSat
New Orby install
Using direct slimline with orby?
