Does anyone know if the older 20 remote, pictured below, can be programmed with the Hopper 3 so it works with pulling up and navigating the guide, accessing the DVR recordings, fast forward, rewind, etc.?
Yes they will work with Joeys and Hoppers. I have been using two since I switched to Hopper/Joey system.Does anyone know if the older 20 remote, pictured below, can be programmed with the Hopper 3 so it works with pulling up and navigating the guide, accessing the DVR recordings, fast forward, rewind, etc.?
To be clear the 20.0/21.0 remotes will have to be pointed at the Hopper or Joey when you use them. They will work if set up right.Yes they will work with Joeys and Hoppers. I have been using two since I switched to Hopper/Joey system.
In other words, via IR. I even have some UHF Pro 6.3 remotes working in IR mode.
Turn on the IR function in the Hopper remote control settings menu. Press the Sat button on the 20.0 remote control. Point it at the Hopper and see if it works. You do not pair this remote like you do with the other remotes. Let us know if it works.Ah okay, so it's just turning on the IR function in Remote Control Settings then?
And then is it just going into Sys Info, then pressing Sat and Record on the remote to get it to work?
If the 20.0 remote doesn't work you need to change the address to #1. Here are the instructions:Turn on the IR function in the Hopper remote control settings menu. Press the Sat button on the 20.0 remote control. Point it at the Hopper and see if it works. You do not pair this remote like you do with the other remotes. Let us know if it works.
I guess the guys on here know a little bit more than our company reps do.Hey there! The Hopper system is not compatible with the 20.0 remote. It is compatible with the 40.0, 50.0, 52.0, and any 54.X remotes.
I guess the guys on here know a little bit more than our company reps do.![]()
Welcome DialgaChampion. Hope you got her working good.Awesome. Thanks for your help and fast responses everyone!![]()
Limited time offer
