I have a Dish 322 with tuner 1 connected to one tv and tuner 2 connected to two tv's. Tuner 1 is IR and tuner 2 is UHF. At this time I have to carry the UHF remote to each room. Can I set up a third remote?
How do I do this
Done!It's been a long, long time since I've even seen a 322 but IIRC you just get the same model remote and make sure it's set to the same code. IIRC the code can be found on the System Info Screen.
Maybe somebody who has a more recent memory can chime in or you can Google it.
Also, a moderator maybe could move this thread to the Dish Network Support Forum.
It's the same as a VIP.It's been a long, long time since I've even seen a 322 but IIRC you just get the same model remote and make sure it's set to the same code. IIRC the code can be found on the System Info Screen.
What is a VIP i bought an identical remote that is used on tuner 2 UHF
It works thank you againThank you i will give it a try
Limited time offer
