Factory Reset Orby Receiver | SatelliteGuys.US
Would you happen to know why Orby only includes one diplexer in their self install kit? I've used diplexers before but had to have one on each end of the cable run.
The OrbyTV receivers use the same coax input for both the terrestrial over the air and the satellite. To simplify the install process of the over the air antenna and the satellite dish, they use a single diplexer outside to connect both of them to a singe coax running inside.
Sent using Tapatalk
Reactions: truckracer
LNB Splitter
Half off Orby TV receivers and DVRs at Best Buy - 10/17/19
