Only if you don't plug it back in again....Will pulling the plug provide different results than "Resetting The Hopper"?
Yes. Pulling the plug is a hard reset. Resetting the Hopper using the red button is soft reset and may also solve the problem.Will pulling the plug provide different results than "Resetting The Hopper"?
Only if you don't plug it back in again....![]()
Of courseI have U540 and have not seen any of the behavior you describe. Did you try pulling the plug to reset the box?
Pulling the plug will "zero out" the box and all components will power up to their expected state asSeriously, Do both methods do the same?
designed by engineers. Soft reset doesn't do that. Power reset will fix some problems that soft reset
can't but it isn't the silver bullet to fix everything. If you do a power reset you won't have to answer the
question "did you do a power reset"?
My guide does that too, but it isn't ruining my life.Will try the unplugging, where the box is located is a pain in the butt but maybe that's what's causing my guide problems.
I pay DISH so my money won't find it's way to Claude's wallet.Not sure how it could ruin anybody's life??
We all pay DI$H for a reason.
GBR!
I like your sarcastic sense of humor, Glynn. You make me lol, oftenI pay DISH so my money won't find it's way to Claude's wallet.
Limited time offer
