I was under the impression that you had to have Orby's subcontractor install the system.
Is this not true?
You may use your own dish and LNB, provided the LNB you use is linear
Is this not true?
Is this not true?
That and covers the standard 11.7-12.2 GHz (10.750 L.O.) satellite FSS band of course ...You may use your own dish and LNB, provided the LNB you use is linear
I'm wondering if someone would be able to take a DirecTV international Dish & LNB and use it for Orby!
Challenge accepted. Let's eat at the Bluestem. It received a AAA 4 Diamond Award last year. Three course dinner is $75. So multiply that by 2 for a couple. Lets add $45 for drinks and wine. So that brings us to $195. Then let's see Captain Marvel 3 times. $8.99 per ticket x 6. That's $53.94. That's $248.94 total
View attachment 137587 View attachment 137588
Is this why Americans are so poor and always living paycheck to paycheck? Who tf spends that much money on overpriced rabbit food? I'm happy to just go to Taco Bell tbh![]()
Oh, nice. If you're going to SoCal may I suggest Wienerschnitzel as your cheap fast food joint option instead?
Is that Der Wienerschnitzel or just Wienerschnitzel? There used to be a chain around here that was typically housed in an A-frame called Der Wienerschnitzel.If you're going to SoCal may I suggest Wienerschnitzel as your cheap fast food joint option instead?
Ordered from ebay this D***TV INTERNATIONAL WORLD DIRECT CHANNELS DISH ANTENNA 95 W LNBF (DIRECTV INTERNATIONAL WORLD DIRECT CHANNELS DISH ANTENNA 95 W LNBF DTV36LNB NEW 796762782529 | eBay) . I quickly fabricated a mount using 3/4"x2-1/2" PVC board from Home D*p*t, but it seems to work great on my old D***TV SlimLine dish for Orby TV.
I saw that too TCP 23 and TCP 111. So telnet and ident. I was going to poke around later on then it updated the software and no longer pulls an IP. I see the nic come up but DHCP seems off now. I wonder if its static now? Not sure how i could find the address now?For 24 hours I sniffed all the packets to my Orby. The only thing it did was DHCP an IP on my network and then didn't do anything else. It doesn't appear to use the network for anything at the moment. I was able to login to the thing and poke around a bit. It's linux with no root password.
Limited time offer
