When you do as manual update to the firmware, you MUST let the HWS finish completely. The menu will come back up, but it is not finished. Just go play a video game and leave the HWS alone for the 1/2 hour needed to complete the update.
Sounds like you and I made the same mistake. Just for me it was based on acting like Mr. Magoo with it.Update: I managed to get the U715 on the 2nd try. I plugged in the Snap module and turned the HWS on. The first thing I saw was the box that said the Snap was installed and working. Paging through the program guide was literally a snap since it was near instant. I'll have to continue my testing to see what else is speeded up. I did notice my wired Joey 2 was completely messed up but a system reset (which took an unusually long time) remedied that. I noticed the Joey didn't seem to benefit from the snap perhaps because it also needs a firmware update.
At this point, I would say that the Snap module is ready for prime time.
You will see a difference with the next software updateI did notice my wired Joey 2 was completely messed up but a system reset (which took an unusually long time) remedied that. I noticed the Joey didn't seem to benefit from the snap perhaps because it also needs a firmware update.
And your snap module wouldn't be recognized until the HWS had the U715, correct?
I received mine today. Quite a difference on menu and guide speed on the HWS. A somewhat less pronounced (but still noticeable difference on the Joeys. No negative effects noticed but Ijhave seen issues solved by and created by the nightly guide download. So we will see. I will report again later in the week.
BTW my wife was amused by the address label. I am not sure which member of the Greczkowski family was responsible but it took my wife about 5 minutes to recover.
For me, I noticed no improvement in my Joey2 performance and I'm on the attest fLike the others the Snap continues to do what its intended for here, speeding up the menus, etc. The Joey performance is noticeably faster, but not as snappy as the H2.
I obviously don't have an understanding of how things work. Why would the Snap module affect Joey performance without a software update?Like the others the Snap continues to do what its intended for here, speeding up the menus, etc. The Joey performance is noticeably faster, but not as snappy as the H2.
I'm guessing that the EPG, etc, graphics are generated in the H2 and sent to the Joey for display. My wife and I both noticed the improvement, and we both agree it's not as snappy as the H2 itself. Scott has mentioned an upcoming update that should improve the performance, so I'm looking forward to seeing what it does.I obviously don't have an understanding of how things work. Why would the Snap module affect Joey performance without a software update?
I have U751 on the Joey2 which i believe is the latest version and the Snap module had no effect on Joey performance.
Bingo.That is an excellent question. If the video is all generated on the Hopper and merely presented on the Joey, then that might explain how the Snap can accelerate both.
Bingo.![]()
Using it on both isn't authorized. It causes problems, so one is all you could use it on for nowI have two HWS. Can I use a snap on one till a new software update?
Sent from my iPad using SatelliteGuys mobile app
Limited time offer
