Titanium Satellite - signal or reciever issues | Page 2 | SatelliteGuys.US
Titanium Satellite signal or reciever issues
I don't have that exact receiver, BUT, arrow down to the bottom line that says: "Start Search" 'Blind', and then try arrow forward or backwards and see if there's a choice to change to "Transponder". If so, it'll also likely let you insert the exact settings you want.
You can look up specific transponders here: Satellite Charts - Search
But that site is NOT the be all or end all site (none are) so sometimes they can list something that's old, BUT, usually they are pretty much correct.
In other words, "Blind Scan" is typically always the first thing to try, followed by a transponder scan if it doesn't pick one up that you KNOW is likely there.
P.S. NICE setup you have there!
At the start search line if you move left it's TP scan if you move right it's
Satellite scan and then you have Blind scan. The line above it is where
I select the TP and hit ok but when I blind scan it, seems like it scans all the TPS
Not just the one selected.
Make sure that when connected to the C-band LNBF that you select 103w C-band from the satellite list.
If you have any splitters or switches in line, remove and direct connect the coax from the receiver to only the C-band LNBF for this test.
I didn't unhook the switch because of thunder but I posted a few pics with Ku and C bands
Go back a menu, isn't there a choice for "Manual Scan"? That's where you would do it.
Do you have the receiver manual? If not, here it is:
Yes I have the manual, but never seen anything for manual scan but after looking
Through it I noticed I can do a NIT deep scan which I will give a try because the
book says you can scan individual transponders there.
Reactions: primestar31
based on the screenshots, looks like you are maybe getting a mix of 101W and 103W in Ku, and 105W in C-Band. That might also explain why you are getting certain things and not others. Maybe the dish is slightly off?
Ok thanks I will try and tweak it a little. Thanks for the info.
AZBOX strange issue with Elite
[Viewsat] Trying to get started on fta cheap.
