-Is the OTA antenna attached to the existing Dish? Does a separate wire need to be run?
-Any recording or guide issues I need to be concerned?
I have Hopper 3
WHERE DOES THE DATA COME FROM?It will download automatically. it may not be populatef till the next day----and eevn then there may be missing data.
By the time you run through 2 duplexes, your loosing 7-10 DB of signal.
Better to run another cable if at all possible
I'm in a strong signal area, and still use a large UHF/VHF antenna on a rotor.
But diplexers aren't splitting the signal, so how are you losing 7-10 db? Where does it get lost?By the time you run through 2 duplexes, your loosing 7-10 DB of signal.
Interesting. What do you use it for? My Washington DC stations and Baltimore stations are all in the same direction (NE). Frederick is a bit closer to north, and Annapolis a bit closer to E.
I used to try to pull in MPT from Hagerstown. Much better than WETA. Didn't work.
Limited time offer
