Directv has an app you can stream with also.. Why replace dvr's with clients... To keep things the same Same playlist and interface
it only streams to a mobile device, not a tv
dvrs add timers, space, and tuners
If you need more than 100 timers and 2TB of storage... you are already in a different class. Most people dont need that.. Which is why the HS17 fits the mold perfectlyit only streams to a mobile device, not a tv
I have 4 kids.. if they are recording that much crap there is other issues that need addressedtell that to my wife..........
or any family with 2 or 3 kids, and no streaming options
i bet its mor common than you think, especially in rural areas
You cant use PIP on a HR24 anywayi can just relay the issues i have read about on the dtv forums
yes there areas are complained about
i didnt even mention people being upset of the loss of PIP
As long as the HS17 doesn't fail since you can't have a DVR as a backup.If you need more than 100 timers and 2TB of storage... you are already in a different class. Most people dont need that.. Which is why the HS17 fits the mold perfectly
But lets be honest.. I have had a HR44/54 and a 17 now for 7 years Neither of them has failedAs long as the HS17 doesn't fail since you can't have a DVR as a backup.
Rather I have had a HR44 first, then a 54 now a 17 Within that 7 years none of have failed..You have had an HS17 for seven years?
I'm glad to hear that none has failed. There are plenty that have and if your HS17 fails, you are SOL until it gets replaced.Rather I have had a HR44 first, then a 54 now a 17 Within that 7 years none of have failed..
That's ok. I can live without tv for 1-2 daysI'm glad to hear that none has failed. There are plenty that have and if your HS17 fails, you are SOL until it gets replaced.
We all can I hope! I just don't want a setup with fewer options rather than more.That's ok. I can live without tv for 1-2 days
I will not give up my "other" recvrs ... I need them when I go camping or tailgating ...If you're going to recommend something or bash something it would be nice to state why. I mean, what exactly does "too confining" mean?
I've had an HS17 with 2 C61Ks and 2 wireless minis for almost two years. It's fine. I have absolutely no complaints and I've seen just about every model of receiver and DVR as an 11-year customer.
D*'s app is seriously questionable ....Directv has an app you can stream with also.. Why replace dvr's with clients... To keep things the same Same playlist and interface
And if it should happen to go down when something important is on ...That's ok. I can live without tv for 1-2 days
There isn't anything that important on. Unless they are airing trump pressing the nuclear button or Jesus arriving nothing on tv is that importantAnd if it should happen to go down when something important is on ...
I know you have had issues but I am usually goodD*'s app is seriously questionable ....
It works fine from time to time ... but not reliable for me ...I know you have had issues but I am usually good
Limited time offer
